Martin
Everything posted by Martin
  1. if a submaster could be "run" or sat at fx 50% thru a memory! Because the problem is when i want to have different tempos i different chases at the same time in a theater-stack...
  2. Yes, but if we could program the preset of the submasters! So when i run a memory the desk "thinks" a special submaster (with a chase on) is on, !
  3. But why not make this feature? it can't take long, and what do we lose with it? it could spare some time!
  4. Why not make it at feature? must be simple to make? memorys recording submaster presets Of course HTP
  5. I would want this: I haVe a chase on a submaster, and if the submaster is raised when i program a memory, the chase will run in the memory. So i want the memorys to record "submaster presets" would be nice !
  6. Are you sure, what if it was movinglights moving on the sub ?
  7. It is not what i want! Is just want it to be like, when i program a memory it shall program all, also raised submasters, so if i got a submaster up with a chase, and I program a memory with som other lights set (preset), so the submaster's chase wil keep running in the memory I program!
  8. No, you miss understand me, i want the whole chase! but when i press program it only take the exact step (that is the problem)! Fx: (this is what happens) I have made a chase with to generic flashing, the chase is on a submaster, i set some other generics at the preset and now i want to program a memory where the chase is running and the generics (preset) is up so i raise the submaster and press program (MEM 1 ) and when i run the memory the chase aren't runing!
  9. Hey, I have a urgent qustion, i have made some chases on the submasters, and i want them included in some memorys so when i set the light i want for the memory and raise the submaster with chase and presses "program" it only includes the one step of the chase that it is on when i press the button, help plz
  10. Martin
    Non-Dim
    Hi I was wondering, is it possible to change the dimmer curves for one or more channels? and if yes, how?
  11. I guess that is very normal, if you hold down a key on your computer keyboard then it will also keep writing that letter...
  12. Hey I have worked with a fatfrog for about 3 years and i have never had any problems with it, It is very goode for theater, but also for "busking" the light to at music show or a concert. It is very user freindly and it is easy to get started... Go for it ! I very high qualiti desk!
  13. Suppose you have a hazer og ar smoke machine, then just put some lanterns pointin vertical! The lanternes shall have a very thin beam og hang a lot of them beside, then it should lokke like bars...
  14. So if fixture 1-12 is thosen (flashin red light) onle the ones that was taggede when i made the pallette wil change ?
  15. My question is, is it posiible to make the palettes so only some fixture3s react on? i want that fx gobo palettet 1-10 involves All fixtures, but 11-20 only involves some of hte fixtures and the other fixtures arent doing anything if i pres the 13, even when they ar all thosen... Hope you understand
  16. Hey I wonderd if it is possibly to make a submaster that rotates the prism/gobo in our movingheads, so when the submaster is 50% the prism/gobo rotates at 50% of the possibly speed... Hope you understand my qustion
  17. Try to program in partial mode, should work, make sure to "untag" the macs when you are en partial mode, then it is possible to program only the generics, see the manual...
  18. The desk is running dmx right? Then all you need is a Demux that tranforms the dmx signal to analog... Martin
