Nin Posted May 9 Report Posted May 9 My Flx 48 seems to be playing up. When I slide a fader up the lights rise and then black out. Also on the same fader if I press the flash button, the lights flash as normal but every so often the level stays at say 100% but the lights are off. thanks Nin
Davidmk Posted May 9 Report Posted May 9 @Nin First off, try test mode - see manual here. If your faders are playing up then maybe servisol will sort it otherwise contact support. 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
