GrantH Posted May 19, 2025 Report Posted May 19, 2025 Hi, We're a highschool running a S24. How do I extract the channel->DMX data into a human readable form? Effectively I want a patch list, so that if we move & re-address a fitting for some reason, we have a reference to put it back The only way I can see i to get the show information from Setup > Save > Advanced > ZerOS | Save Complete show. This generates a zip file, from which I could possibly reverse engineer from the XML files, but this seems are real hack, and a lot of effort for something that should really exist? Quote
Davidmk Posted May 19, 2025 Report Posted May 19, 2025 Save the show as .CSV. open this in a spreadsheet. The top row is a map of all fixtures and their parameter channels. You may have to put at least one cue on the master PB and it may need to include a cue that references every fixture. I can't remember. I also can't remember if channel numbers or addresses are included. I've only used it to check cues and parameter values. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
