Hi to all.
I am hoping that one of you may be able to help with a list of the correct Bios settings for the Orb desk.  Ours has sideview reset its Bios settings to default. Through lengthy trial and error, the desk has finally been made to work again and it now loads ZerOS as normal but I have been unable to make the Monitor 2 video output show the correct colours on the display. (It's not a display issue - I've tried swapping over). Monitor 1 video is fine. How is the Monitor 2 video generated?
Many thanks for any words of wisdom!
Best regards,
Martin
Hi @Martin J,
I'm fairly confident that Frog2 and Orb Series consoles have the same BIOS as each other, so when I'm home I'll make a list of all the BIOS settings for you.
Failing that, some soldered connections on the VGA connector itself for monitor 2 may be faulty, therefore not giving all colours on the display output.
The VGA port has individual pins for Red, Green and Blue colours, so one of those might be causing the issue you're experiencing.
Archie
Archie - Student
Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Level 6 DMX, Level 12, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, Linebacker, Demux 48 (x2)
Hi Martin,
The only BIOS section which pops out to me regarding this issue is Advanced > Display Control.
The settings are as follows:
  • Display Mode: [CRT+LFP]
  • Flat Panel Type: [XGA 1x18]
  • Flat Panel Scaling: [Stretched]
If those settings are already as listed, it may be a dodgy connection internally to the Monitor 2 VGA port causing a colour to not be output, giving you an image without the correct colours. If you're confident in opening the desk, it would be worth checking this.
I hope this helps.
Archie
Archie - Student
Hi Martin,
No problem - let me know how you get on.
Archie
Archie - Student
  • 2 weeks later...
On 7/10/2026 at 12:20 PM, Archie D said:
Hi Martin,
Archie
Hi Archie - yes, it is the Flat Panel Type setting which needs to be 'XGA 1x18' rather than 'Auto' which is what the default setting is.
For information, the only other setting which needs to be changed after defaults have been loaded is under Advanced Chipset Control, where 'Enable Memory Gap' needs to be set to 'Extended' rather than 'Disabled'. Otherwise you get a permanent 'Non-volatile RAM Fail/Replace Battery' message at boot-up.
Very many thanks for your help - this was driving me insane!
Martin
Hi Martin,
Really glad to hear this - I'm glad you've got it sorted. Nice find on the extra setting for the NVRAM!
Happy to help.
Archie
Archie - Student
