Carl Ehrhardt Posted November 3, 2003 Report Posted November 3, 2003 I am not sure if it has been listed somwhere else already... if not: here is a bug: :cry: if i name a submaster it doesn't save the information. As soon as i have switched off the desk and switch it on they are no more there. also if i save the show on a disk it doesen't come back unfortunately. Hope you can fix it :wink: Greatings Carl Ehrhardt Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
KWR88 Posted November 3, 2003 Report Posted November 3, 2003 First is it only the name that is not saving or is it the channel/transfered information as well. If it is only the name then I have not seen this problem before on the Illusion and will have to make some tests. It would help if you could e-mail a copy of the show file to me. If it lossing the channel info as well them it may be either a battery problem or an incorrectly seated or possibly even a fault Din ram moduel. Regards, Keith Rogers Zero 88 Support: support@zero88.com
Carl Ehrhardt Posted November 3, 2003 Author Report Posted November 3, 2003 it's only the name... i can send you the show or one of thoses shows... it's in every show we make... but chanaldata, fadingtimes are still saved. well as fare as i think... but i will try it tonight. tell me where i can send the file to. Thanks for your Help! Greatings Carl Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
KWR88 Posted November 3, 2003 Report Posted November 3, 2003 Please send the show to krogers@zero88.com As I said I can think of anything that would lose the names only but will have a look at yuor show and get back to you. Regards, Keith Rogers Zero 88 Support: support@zero88.com
