arnout cx Posted September 21, 2005 Report Posted September 21, 2005 Hi, I`m having some problems with my Sirius 250. I can`t get my dimmer levels over 92% and under 5%. It`s not always and some times it`s for 5 min. But sometimes it can be weeks till it`s over and I have tried with updating the software but it doesn`t work. Can somebody help me who knows what it is and what I can do about it Thanks, Arnout de letter Cx sound & light (p.s. sorry for my bad English I`m from the Nederlands)
ice Posted September 21, 2005 Report Posted September 21, 2005 (in Dutch) Als je Nederlands advies wilt: bel even met de TD van Rolight. Die zijn importeur van Zero88 in Nederland en weten dit misschien wel. > 500 posts, time for a new T-shirt?
arnout cx Posted September 22, 2005 Author Report Posted September 22, 2005 (in Dutch) hi, Heb geprobeerd bij Rolight maar die wisten het niet omdat hun de Sirius nooit hebben meegemaakt. Toen was dat nog bij flashlight. maar toch bedankt. (in English) hi, I tried with the Dutch distributor (Rolight) but they didn`t know what caused the problem. Because they had no experience with the Sirius 250 does somebody know what I can do about it thanks. Arnout de letter Cx sound & light
KWR88 Posted September 23, 2005 Report Posted September 23, 2005 Dear Arnout, The two most obvious thing that I can think of are; A fault with the master PCB faders. Either a damaged fader or something like a loose connection to the PCB. Also check the switch on the back of the preset PCB that identify which channels they are controlling as if this has moved or is faulty and reading as another PCB it can cause the multiplex lines to be out of sync and you will see this sort of problem. Regards, Keith Rogers Zero 88 Support: support@zero88.com
arnout cx Posted September 25, 2005 Author Report Posted September 25, 2005 thank you, i will control that. i send you an email with some details i want to know hope you can help me also with that regards, arnout
