ArtizZ Posted November 28, 2008 Report Share Posted November 28, 2008 It`s not possible to load from Fixture Library Clay Paky Alpha Wash 1200 moving head. It's show error! Quote Link to comment Share on other sites More sharing options...
Paul Posted November 28, 2008 Report Share Posted November 28, 2008 This is a bug that's been in JesterML since day one I'm afraid - you're the first to find it, because the particular fixture personalities you're trying to load have long names in the fixture library... Alpha Wash 1200 : 16 Bit Vector Disabled Alpha Wash 1200 : 16 Bit Vector Enabled Alpha Wash 1200 : Extended Vector Disabled Alpha Wash 1200 : Extended Vector Enabled Alpha Wash 1200 : Standard Vector Disabled Alpha Wash 1200 : Standard Vector Enabled The fixture will fail to load correctly on the JesterML if the first part (before the colon) is longer than 30 characters, or the second part (after the colon) is longer than 18 characters. I have attached a fixture file with these long names removed for these 6 fixtures. You can do this yourself for other fixtures if necessary by using the Fixture Type Editor to extract the fixture personalities you require out of the main library. The long names (which aren't actually visible in the current version of the Fixture Type Editor) will be removed in the saved file. Use the Load From USB option in Assign Fixtures to use this file on the JesterML. The bug will be fixed in the next version of the JesterML software: JES-2531 - Problems assigning fixtures with long names. CPAW1200.ift Quote Link to comment Share on other sites More sharing options...
