Peeter Posted August 25, 2010 Report Posted August 25, 2010 Hi! I am a newbie in this matter, so i decided to ask. Is it possible to upgrade JesterML 24 version 2.0 to 3.0 and does it reset the whole desk (clears the presets and fixture libraries) if it does, then is it possible to make backup? Fast help is appreciated. Thanks for advance Peeter
Jon Hole Posted August 25, 2010 Report Posted August 25, 2010 Hi Peeter, It sure is. First, take a backup to USB. This is done through super user, and is explained on page 45 of the manual, available here: http://common.zero88.com/public/files/7340600_JesterML_Manual_3_0.pdf Then, download the software from here onto a USB stick: http://support.zero88.com/main/en/product/89 There are instructions on how to do this here: http://common.zero88.com/public/files/JesterSoftwareUpdateInstructionsIssue3.pdf Once you have done this, you can reload your show from the original USB stick, also through super user. Hope this helps, Jon Hole linkedin.com/in/jonhole
Peeter Posted August 26, 2010 Author Report Posted August 26, 2010 Thanks for the help! Worked like a charm also updated fixtures list and now i can use Martin Mac 301 Wash Peeter
