Roger T. Posted January 14, 2011 Report Posted January 14, 2011 I have prolems with LED Equipment (as ParLite LED or StripLite LED) in the "Run"-Mode of a Lightmaster XL. Independent of the DMX-Patch every Fader (if it's in the position between 80-100%) interrupt the previous Fader. Example 1: Fader1 Red (Fader @ 0%) Fader2 Green (Fader between 80-100%) Fault: Green LED's are on and the Red LED's are flickering a little bit Example 2: Fader7 Green Fader8 "no DMX-Patch" (Fader between 80-100%) Fault: the Green LED's are flickering a little bit In the Preset-Mode and Program-Mode there is no Problem! I have done the Reset and Factory-Reset routine. Is anybody able to relate this? Is it a Fault of the Desk? If "Yes" in which Part is the fault (i have the Schematics) Any Ideas?
KWR88 Posted January 14, 2011 Report Posted January 14, 2011 Not seen anything like this that only shows up in Run mode. Any sort of fader fault would show in preset, program and run. Are you using the A preset live control in run mode or have you programmed the levels the B memory masters and repaly from there? Please e-mail me back on the address in the signature below. Regards, Keith Rogers Zero 88 Support: support@zero88.com
