Hi
I am doing a show tomorrow where I need to use DMX relay packs to kill the fan noise from my moving heads during the quiet bits.
I have found 2 ways to do this:
1) to program the relays onto MFK's using the relay profile from the standard fixtures list
2) using the dimmer sliders to control the relays directly
My problem is that I want to be able to enable/disable the lights and know that their state will stay fixed until I choose otherwise. I don't want the [clear] or [home] buttons to affect the relay setting. How do I fence off selected sliders, or alternatively, how do I create a relay fixture that is immune from the clear/home functions?
Many thanks
Hi Oysterbandit,
I would suggest using Submasters as these don't get affected by the clear button.
You can also change what the fixture / relay does when you press HOME in SETUP > PATCH > EDIT FIXTURES > DEFAULT / HOME.
Use the flash buttons / MFKs to 'select' the fixtures, so they appear in the list. You can then edit these values by double clicking in a cell, or selecting it and pressing ENTER.
I hope this helps?
