Hello friends!
I need an easy way (i use non tracking mode) to copy a movinglight from another cue into the live mode. I tried to make it with the palettes, but this is to much complicated, because we do programming in live mode (in general rehearsal for example, i cant go back to another cue).
Many thanx!
yes it is possible to do this.
If you use the syntax fixture no: @ cue x enter.
i.e. 101@cue 5 enter, will output the fixture attributes recorded into cue 5 live.
Regards,
Keith Rogers
