b.a.m sound and lighting Posted May 29, 2015 Report Share Posted May 29, 2015 Hi I am having trouble with blending colours using sub masters, I have set up 4submaster: sub1 fixture intensity, sub2 red, sub3 green and sub4 blue. They work fine separately ie sub1+sub2 @ 100%, but if I add sub4 @100% to create purple it knocks off sub2 and leaves just blue All subs are set to HTP Is there anything I can do? Thank you in advance, Ben Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 29, 2015 Report Share Posted May 29, 2015 Hi Ben, Have a look at this article and see if it helps. If it doesn't, let us know and we'll go through it in a little more detail. http://www.zero88.com/support/index.php?/Knowledgebase/Article/View/585/ Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
b.a.m sound and lighting Posted May 30, 2015 Author Report Share Posted May 30, 2015 Thank you that's done the trick, I wasn't untagging Quote Link to comment Share on other sites More sharing options...
