Tbeunders Posted December 14, 2015 Report Posted December 14, 2015 Hi, Since sometime, I haven't been able to use the remote monitor app, Android version and Windows. I'm not sure since when this happend but I think it was after an update. I use the LeapFrog 96. Thank you, Thomas Beunders
Jon Hole Posted December 14, 2015 Report Posted December 14, 2015 Hi Thomas, Have you enabled it within SETUP > Network > Remote? If you updated your software and didn't load a showfile back in, it would probably be disabled. If you have done that, please let me know the IP address of your console and the apps. Many thanks Jon Jon Hole linkedin.com/in/jonhole
Tbeunders Posted December 14, 2015 Author Report Posted December 14, 2015 Yes i already enabled it, but i tried it today again and he does find the table when using manual connect but otherwise it does not work. The pc and the leapfrog are both connected to the same network and the ip from the leapfrog is 196.168.0.102
