  1. Today
  2. @kgallen I don't have much experience with multi pixel fixtures but would this work? Select each pixel that should.come on together and record a group. Repeat until all the required pixels are in a group. Select the groups not the pixels. Run the effect by groups rather individually. Failing that... If the effect can work on a single fixture then giving them the same address will make them behave the same but rule out treating them individually. Heaven knows what it would do to RDM though. You can patch multiple fixtures, on different addresses to the same channel. Again that stops you treating them separately in this show but they can still be patched separately in another show Or build an actual chase recording each step separately.
  3. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now tu hi hai kya baat hai
  4. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eu jd and friends
  5. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eu jd and friends with
  6. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eyy thom thom look forward and
  7. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now dj remix songs a na
  8. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now duu ght and your
  9. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now di s s snjsbshf
  10. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Ekji and friends with you
  11. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eu jd and your ytyyy
  12. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eu jd and your ytyyy
  13. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now Eu jd jj and your
  14. Hope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call nowHope Fund Loan Customer care helpline number ☎️+91_79❽❼⓿❾+:: +91-7970355140 call now go to understand I will send it
  15. Yesterday
  16. Simplest solution is to have all of the fixtures as one dmx address. Assuming that isn't an option or not ideal, it does seem to be a tricky one that I don't believe the video kgallen has pointed to actually addresses. It covers doing what you're already able to do - I watched it not that long ago as I was interested to do what you want to do and ended up just putting them on one dmx address for speed, but have been meaning to experiment since. I suspect you may be able to save the parameters of the effect to a palette, then apply it to individual fixtures in turn, until all of them are doing the same. I'm not convinced it won't just start rolling into doing what you already have though as soon as you add each fixture. Last option is manually creating your own playbacks with as many cues as required to make the effect. As far as I can see though, when you select pixels across multiple lights, the desk just treats them as a big line of lights and doesn't seem to have any understanding of grouping them into fixtures.
  17. Thanks Kgallen, I reproduced it in the channels mode I needed in no time with Fixture Editor 😉
  18. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. To d
  19. Hmmm not sure I know of a way. Want to upload the zfix here so we can have a play?
  20. is it possible to transform a .zfix fixture file from my s48 into an .ift file to be read by my beloved Frog2 without rebuilding it with the Fixure Editor. Thank you P.
  21. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji ek a very good
  22. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji ej sjs sjs anakns
  23. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji shub prabhat dosto ko
  24. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji smjh hii sir sir
