  1. Yesterday
  2. On S24/S48 many of the buttons are ‘soft’ at the top of the touch screen. To busk and avoid snaps in general, go into the Z screen and enable Programmer Time with the 5secs or whatever value you want. This video will be useful
  3. SmartTag will record 0% intensity. That’s the one thing it definitely does. What it won’t do is record changes to other parameters at the same time. If you want to record other parameters changes (or the classic Effect Off) at the same time as the fixture goes to 0% then turn off SmartTag for that record operation - remembering to turn it back on for the next one (you can just hit record, turn it on then hit record again to clear the options box without actually recording anything).
  4. Hi, seen how to record palettes on FLX, but FLX S24 does not have a colour button so how to do this on S24. Also wondering if there is a way of busking with pallets and not having colours snap. For example, going from Blue to red during a show using the pallets without programming a Cue. Looked at PDF and online web manual and can't find anything. Ben
  5. Hi, so as SmartTag does not record 0%, how do I record a 0% with this enabled? Shame there is not an option to do this with SmartTag for intensity. Ben
  6. Thansk, that great to know
  7. Last week
  8. Selecting each set and using and between them would be the same as 1.1 thru 3.8. Which would span the effect across all the pixels, not apply the effect to 1.1 thru 1.8 and the have 2.1 thru 2.8 do the same thing. What I didn't try was recording a group of say 1.1 thru 4.8, setting an effect on that and recording it as a pallete then trying to apply that to 1.1 thru 1.8 individually then applying it to 2.1 thru 2.8 and so on.
  9. 1.1 thru 1.8 and 2.1 thru 2.8 and 3.1 thru 3.8.. and so on. Should be able to save that as a pre pallet as well, group or fx
  10. Was also trying to do this recently. I selected all the pixels in 1 fixture, so 1.1 thru 1.8 and created the effect I wanted and saved it as a pallete. I could not how ever apply this pallete to any of the othe fixtures, I had to create the effect on each fixture individually. Helped by recording a load of groups during pre programming, so each fixtures pixels as a group, all pixels in the first 4 fixtures as a group and so on...... Then I could just select the group, tap effects, tap chase, adjust a few things and record. More time consuming as i had 24 fixtures each with 8 pixels but the only way I could get it to work.
  11. Note that setting default and home values in ZEROS (certainly on FLX) gets munged by "smart" settings which should be turned off when recording them. That has caught me out a couple of times.
  12. Save the show as .CSV. open this in a spreadsheet. The top row is a map of all fixtures and their parameter channels. You may have to put at least one cue on the master PB and it may need to include a cue that references every fixture. I can't remember. I also can't remember if channel numbers or addresses are included. I've only used it to check cues and parameter values.
  13. Hi, We're a highschool running a S24. How do I extract the channel->DMX data into a human readable form? Effectively I want a patch list, so that if we move & re-address a fitting for some reason, we have a reference to put it back The only way I can see i to get the show information from Setup > Save > Advanced > ZerOS | Save Complete show. This generates a zip file, from which I could possibly reverse engineer from the XML files, but this seems are real hack, and a lot of effort for something that should really exist?
  14. @kgallen I don't have much experience with multi pixel fixtures but would this work? Select each pixel that should.come on together and record a group. Repeat until all the required pixels are in a group. Select the groups not the pixels. Run the effect by groups rather individually. Failing that... If the effect can work on a single fixture then giving them the same address will make them behave the same but rule out treating them individually. Heaven knows what it would do to RDM though. You can patch multiple fixtures, on different addresses to the same channel. Again that stops you treating them separately in this show but they can still be patched separately in another show Or build an actual chase recording each step separately.
  15. Simplest solution is to have all of the fixtures as one dmx address. Assuming that isn't an option or not ideal, it does seem to be a tricky one that I don't believe the video kgallen has pointed to actually addresses. It covers doing what you're already able to do - I watched it not that long ago as I was interested to do what you want to do and ended up just putting them on one dmx address for speed, but have been meaning to experiment since. I suspect you may be able to save the parameters of the effect to a palette, then apply it to individual fixtures in turn, until all of them are doing the same. I'm not convinced it won't just start rolling into doing what you already have though as soon as you add each fixture. Last option is manually creating your own playbacks with as many cues as required to make the effect. As far as I can see though, when you select pixels across multiple lights, the desk just treats them as a big line of lights and doesn't seem to have any understanding of grouping them into fixtures.
  16. Thanks Kgallen, I reproduced it in the channels mode I needed in no time with Fixture Editor 😉
  17. Hmmm not sure I know of a way. Want to upload the zfix here so we can have a play?
  18. Earlier
  19. is it possible to transform a .zfix fixture file from my s48 into an .ift file to be read by my beloved Frog2 without rebuilding it with the Fixure Editor. Thank you P.
  20. There is a Search panel to search manufacturers and another for models. Maybe an external USB keyboard would help? If you have a recent ZerOS, your most recent patch fixtures should be at the top of a list as "favourites". https://www.zero88.com/manuals/zeros/patching/add-fixtures/searching-filtering
  21. Bonjour, comment retrouver mes marques de projecteurs ( caméo, robert juliat, Stairway) sans passer par la bibliothèque ? À chaque fois que patch , il faut que je les récupère dans la bibliothèque ce qui n'est pas très facile Merci
  22. Hi there, we have a problem with the default attributes of our LED Fixtures. Till version 7.___ it was without problems possible to record the defaults atttributes for each fixture with "record" "home" "defaults". Now with version 8 thsi works as well but it happens the following: after each restart even if the values of all attributes are recorded correctly and double checked before switching of the concole, the default attributes are erased and it happens there are random attributes recorded e.g. white 82, red 0, green 18 and blue 2. Can anybody help? One more thought: Perhaps it's only coincidence and has nothing to do with the new version of the ZeroOS and the internal memory of our Console is damaged!? Best, Bernhard
  23. This video on multicell for FLX S might help, or as revision:
  24. I have some pixel batten fixtures. When I run a chase effect across a fixture it chases across those pixels. When I run the effect across multiple fixtures, it will chase across them all in order. I’d like for all the battens to pixel chase at the same time as a group. I thought it could be something to do with the offset of the effect, however when I select ‘offset as group’ it ignores the pixels and treats each batten as a single light source. I’ve attached a video of how it works currently and an edited video of how I want it to be able to work. How it works now: https://youtu.be/gVSUg7lTL2w How I want it to work: https://youtu.be/qIHcmw-siQs Is there something I’m missing? Thanks!
  25. Davidmk
    ninian
  26. Nin
    ninian
  27. @dtyotam See this post for links to the (Google) Apps:
