- Past hour
Goofy started following Position Palette
Hello I have a question about saving positions in a palette. When I move a moving head to a specific position and change the zoom, and then save it to the Positions palette, it only saves the position, but not the zoom (beam shape). I've tried many options in the Record window, but to no avail. However, if I move to the position, adjust the zoom, and then save it to the position via Update, it includes the zoom. Why doesn't the console save both parameters (position and beam shape) in the Positions palette? Greetings, Goofy Translated with Google from German to English
On S24/S48 many of the buttons are ‘soft’ at the top of the touch screen. To busk and avoid snaps in general, go into the Z screen and enable Programmer Time with the 5secs or whatever value you want. This video will be useful
SmartTag will record 0% intensity. That’s the one thing it definitely does. What it won’t do is record changes to other parameters at the same time. If you want to record other parameters changes (or the classic Effect Off) at the same time as the fixture goes to 0% then turn off SmartTag for that record operation - remembering to turn it back on for the next one (you can just hit record, turn it on then hit record again to clear the options box without actually recording anything).
Hi, seen how to record palettes on FLX, but FLX S24 does not have a colour button so how to do this on S24. Also wondering if there is a way of busking with pallets and not having colours snap. For example, going from Blue to red during a show using the pallets without programming a Cue. Looked at PDF and online web manual and can't find anything. Ben
Hi, so as SmartTag does not record 0%, how do I record a 0% with this enabled? Shame there is not an option to do this with SmartTag for intensity. Ben
Thansk, that great to know
Selecting each set and using and between them would be the same as 1.1 thru 3.8. Which would span the effect across all the pixels, not apply the effect to 1.1 thru 1.8 and the have 2.1 thru 2.8 do the same thing. What I didn't try was recording a group of say 1.1 thru 4.8, setting an effect on that and recording it as a pallete then trying to apply that to 1.1 thru 1.8 individually then applying it to 2.1 thru 2.8 and so on.
Was also trying to do this recently. I selected all the pixels in 1 fixture, so 1.1 thru 1.8 and created the effect I wanted and saved it as a pallete. I could not how ever apply this pallete to any of the othe fixtures, I had to create the effect on each fixture individually. Helped by recording a load of groups during pre programming, so each fixtures pixels as a group, all pixels in the first 4 fixtures as a group and so on...... Then I could just select the group, tap effects, tap chase, adjust a few things and record. More time consuming as i had 24 fixtures each with 8 pixels but the only way I could get it to work.
delicolor replied to Phil Mckerracher's topic in General Discussion
Note that setting default and home values in ZEROS (certainly on FLX) gets munged by "smart" settings which should be turned off when recording them. That has caught me out a couple of times. -
Davidmk started following Exporting DMX-channel patching to a CSV
Save the show as .CSV. open this in a spreadsheet. The top row is a map of all fixtures and their parameter channels. You may have to put at least one cue on the master PB and it may need to include a cue that references every fixture. I can't remember. I also can't remember if channel numbers or addresses are included. I've only used it to check cues and parameter values.
GrantH started following Exporting DMX-channel patching to a CSV
Hi, We're a highschool running a S24. How do I extract the channel->DMX data into a human readable form? Effectively I want a patch list, so that if we move & re-address a fitting for some reason, we have a reference to put it back The only way I can see i to get the show information from Setup > Save > Advanced > ZerOS | Save Complete show. This generates a zip file, from which I could possibly reverse engineer from the XML files, but this seems are real hack, and a lot of effort for something that should really exist?
GrantH joined the community
kgallen started following Retrouvez ses projecteurs and Fixtures from .zfix to .ift
d
Mr Ed started following Failure saving default attributes of LED fixtures on the FLX
Hi there, we have a problem with the default attributes of our LED Fixtures. Till version 7.___ it was without problems possible to record the defaults atttributes for each fixture with "record" "home" "defaults". Now with version 8 thsi works as well but it happens the following: after each restart even if the values of all attributes are recorded correctly and double checked before switching of the concole, the default attributes are erased and it happens there are random attributes recorded e.g. white 82, red 0, green 18 and blue 2. Can anybody help? One more thought: Perhaps it's only coincidence and has nothing to do with the new version of the ZeroOS and the internal memory of our Console is damaged!? Best, Bernhard
