  1. Today
  2. You've just blown my mind that I've never thought to see if there was a setup menu for each of the CBE pallette windows. I dread to think hour many hours of training videos you had to go through to find that! I will have to have an experiment now as well.
  3. Yesterday
  4. Bad luck then. By chance do you (or anyone else) happen to remember the URL to that page, or have it saved anywhere? We could always check https://web.archive.org/ on the wayback machine to see if anybody archived it.. Or do you mean this page? https://backstage.zero88.com/control (further down it has legacy products - they just give the same descriptions as on the Vari-Lite pages)
  5. There used to be a huge archive page of Z88 products but seems like the Signify folks got rid of it - it only went down a few months ago. Real shame as it had a lot of great info including all the old desks...
  6. I've had no progress on any, might try giving them a ring...
  7. Last week
  8. Thanks everyone for your help on this, after digging through a good few training webinars on YouTube, I came across the simplest answer - offset, specifically how the offset fans across fixtures. You can change this behaviour by holding setup and tapping effects. I set my shift click to be 'fan first' (Also experimented with the other fan options for different effects) then selected my fixtures, hit chase, held shift and span the encoder wheel to fan the offset of the effect until the chase matched up on all battens. Worked super nicely and certainly opens up some more interesting possibilities for programming Battens Chase LQ.mp4
  9. Hi @Tim Molyneux, I'm glad the above solution worked for you. Indeed. You can use 'User File' instead of selecting 'USB' on the MFKs, which allows you to recall fixture profiles from a file previously loading in to the console via USB. At any time if you wish to delete these files from the internal console memory, you can do so by navigating to the <Update Fixture Lib> menu within setup. From there, you can select <Delete User Files>. Use the arrow keys to navigate which file you would like to delete from the internal console memory. Hope this helps!
  10. Strange, I did hear somewhere that the Jester did, although it just could be my head playing tricks on me. You are probably right in what you've presented here with the line-up of consoles, so I appreciate the confirmation. It also can store memories (or 'steps' as it calls them, each step being part of a 'sequence') as well as having the ability of being in 2 preset mode. I've had a play with mine at home and although rather simple in the operation of it, I admire its simplicity. Thank you for the information you have provided me regarding the data sheet and the manual dates, I think I can try and work on figuring out dates with the info provided. I will continue to do some more digging on the forums as you have advised. Thank you again and have a lovely day!
  11. Thanks everyone for you support - I'm delighted to say the file has loaded correctly using 'assign fixtures' from USB as you advised. Your time and help are really appreciated. One last query - will the file be stored in the console library for future use now that it is in the desk? Thanks, Tim
  12. Juggler was a ‘simple’ 2-preset desk so I don’t think it was superseded by Jester which is a programmable desk. I think the lineage was more like: Level series -> Juggler Alcora/Elara -> Jester Illusion -> Jester TL, ML Sirius -> Frogs Stage Electrics had Juggler in stock (albeit clearance) earlier this year. I’ve not seen Jesters on sale new for a long time. So in answer to your question, Juggler could have been current until 2021/22 timeframe I recon. The datasheet says ‘(c) 2018-2021 Signify’ as a copyright date. The Juggler manual says 2005. So it was around for some time. Maybe search on the forum to see if Jon mentioned a discontinue date.
  13. Hi all, hope you are well. I was just curious.. from when to when were the Jugglers being manufactured? Usually, on a page (for example the Jester Series https://www.vari-lite.com/global/products/jester-series) it tells you when they were manufactured, this case being 2008-2017 for the ML range. However, on the Juggler page (https://www.vari-lite.com/global/products/juggler) it does not mention the manufacture date anywhere. I am aware that the Jester Series superseded the Juggler, but does anybody know this information per chance? Many thanks for any info you can supply me with.
  14. Jon's departure post says this is the official contact email address to use: Conversely, the Vari-Lite website (https://www.vari-lite.com/global/support/technical-support) says to use support@zero88.com - I imagine this redirects somewhere new now...
  15. Just to be sure, people in this thread who have already emailed support (@ATC Tech and @Charlie Newman) and haven't got a reply, have you used one of the old email routes, or the functional one? I've used this address, 'zero88support@signify.com' and have got replies before.
  16. Following as i have the same problem for IOS here in Australia. I have downloaded before on other iPhones and iPad but can’t download now. Not available in my region error. I have emailed support, but no response yet.
  17. Unfortunately, same issue here too. I cannot seem to find any trace of the ZerOS Monitor and Remote apps on the Apple App Store, even in the ‘My Purchases’ section which is meant to show every app on your device added via the App Store. Luckily I have them downloaded already on two iPhones and two iPads and they still work. Hopefully we shall see what happens with the email to Signify. If I remember correctly, these apps were still under the Eaton Apple Developer App Store account. Not sure.
  18. Hi @Tim Molyneux, the above post should definitely solve your problem (thank you @mikeb) as you are trying to load in a fixture personality file in the way of loading a fixture library file onto the desk. Using 'Assign Fixtures' -> USB as described in the manual above will work. Regarding this, I thought I'd just chip in and mention about file formats for future reference: JOS files are the file format for the Jester operating system when updating the console's OS. JSF files are showfiles for Jesters in the 12/24 and 24/48 range. JML files are showfiles for Jesters in the ML range, TL and TLextra range. I hope this is of use for the future for file format knowledge. Edit: To add, I have attempted to upload the IFT file provided above on my own JesterML console using the method in the manual via 'Assign Fixtures' and it does load in correctly.
  19. A JOS file is likely to be a showfile. A fixture personality file is an IFT file so it may be they way you're trying to load the IFT file? Found this from Ed on another forum... The <Update Library> option in Super User can be used to update the fixture library on the console. If you just wish to load in a fixture file, not a whole library, please see page 49 of the Jester TL manual for information on assigning fixtures… https://www.zero88.com/storage/downloads/5ebda1d3-7348-4727-ae31-fecedf299a46/Jester-TL-and-TLXtra-Manual-3.0.pdf#page=49
  20. I'm like Ben in the thread - at the limit if my abilities. Any help is massively appreciated. I had to spend the last £200 on these cheap and cheerful movers for the Drama studio (at last I have an A level lighting student!), they don't need to be brilliant but they do need to work, otherwise I'm in for an awkward conversation with the school finance office.
  21. That’s weird. I see from this thread, I wrote an IFT fixture for another user using the 2.6 fixture tools and he reports it loaded and worked ok. This needs more investigation…
  22. Bad news I'm sorry to say, the desk is coming up with the same error 'wrong file type'. I wonder if it should be a JOS file? Is it worth me deleting the library and starting again do you think? Thanks, Tim
  23. Hi Philh, having the same issue here. I've contacted Signify but I don't have the world of confidence in getting a reply unfortunately.
  24. Thanks so much for your help Mike, I'll try it later today and let you know. Tim
  25. I was using the iOS version of zeros remote but after a recent change of iPad I find it is “ no longer available in your region” I use it frequently is there a solution?
  26. Hi Give the attached a go and let us know how it goes LeLight LED Moving.ift
  27. Hi The 17ch IFT seems empty and the 25ch IFT only shows 4 DMX channels with just a dimmer. I'll look to create a single IFT file that contains both modes
  28. Thanks for the reply. I started the new thread when I noticed how old the previous one was - I'm delighted you are here. I have attached the 2 files I created using the software on this link (2.6): https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/zero-88-fixture-tools-2.6.zip It is very possible I set one of the parameters incorrectly - I am not (by any means) a lighting expert. I have also attached the channel descriptors for the light in case you are able to spot any errors - assuming you are happy to give the time. Thanks again, Tim LeLight LED Moving 17ch.ift LeLight LED Moving 25ch.ift
