  1. Past hour
  2. You're a star. Took me a minute to get the ports talking but it is working beautifully.
  3. Today
  4. Yesterday
  5. The Vari-Lite service department has been very helpful. Thank you Ryan and Kgallen.
  6. Last week
  7. @kgallen PM sent.
  8. I don't have a Jester or any service information sorry, but you might want to check out my post below to see if you have a similar issue. Actually... looking through my emails, seems we've already conversed on this on the Blue Room. Sorry for the repeated info, I guess that's not the issue then? Also on a PM on BR I gave you some instructions for contacting the current support. Did you use those?
  9. I don't have a Jester or any service information sorry, but you might want to check out my post below to see if you have a similar issue. I will also send you a PM.
  10. Hi I have a Zero-88 Jester ML24 lighting controller. It gets used for local charity and non-profit shows. I suspect there is an internal fault with how the faders are multiplexed. The most obvious fault is that the Grand Master fader will only go to 75%, but operating other faders will make it go to 100% as they get to full travel. In test mode, the flash buttons work correctly, but the associated fader will not be 'read' correctly, however another nearby fader will operate in place of the desired one. There is a new battery installed, the desk has been reset and the last available firmware and fixture library installed. I've made up and tried a new ribbon cable assembly in case the original was faulty. Is it possible to get internal schematic diagrams for this desk so I can get busy with a 'scope and meter? Thank you.
  11. Hi @CestM0i64, In ZerOS, Playback 0 is the master playback, so using OSC (e.g. /zeros/cue/go/0/20) will go to cue 20 in the Master Playback. Therefore, Playback 1 will be go/1/<cue number>, and so on. Hope this helps, feel free to ask any more questions you may have. Archie
  12. As per this article I'd like to trigger a cue using OSC. https://www.zero88.com/manuals/zeros/setup/triggers/osc-examples Is the master fader addressed as 1 and then subsequent faders are incremented e.g. Master = 1, playback 1 = 2 or does it have a separate address e.g. 0, M? I'm not currently at the desk so trying to get ahead of the game before I go to programme a show in a couple days where I'd like to trigger some cues from QLAB when they coincide with SFX & VFX cues.
  13. Thank you so much!
  14. Your fault is probably in “cue 2” where there are blocking values that stop the mover prepping for “cue 3” but in your real cue list where you’ve been copying what I said in previous posts is most likely the case. I’m assuming here you haven’t deliberately set ‘Don’t Move’ in any related cue Cue Settings - if you have that’s self explanatory!
  15. See https://www.zero88.com/manuals/zeros/cues-playbacks/playback-settings/advanced?filter=2 for whole playback unblock.
  16. Copying cues results in blocking cues when you paste. You will see white intensity numbers in the output screen. 1. Save your show. 2. GO into a cue you copied to, which shows the white intensity numbers. 3. Press and hold UPDATE to bring up the options window. Ensure SmartTag is enabled (red stripe). Press enter (or tap the playback go button) Blocked values should change from white to purple (tracked) (unless you subsequently changed them after pasting in which case they will be blue or green) and now your move on dark into that cue should work. 4. Repeat for other copy-pasted cues. Note: There is a method to unblock a whole playback in one go but I can’t remember where that option is. Check the manual. 4. Check the results on stage.
  17. Our show (opening in 2 days) is now lit, but in the process (including inserts and copying), for some cues the movers do not move on dark. ('Move on dark' is set on the board, a FLXs 48). I assume that in the editing process, somehow the move on dark or track forwards functions have been corrupted in one or more cues. Simplistically, if I had 3 cues: 1. mover (working) 2. dark 3. mover (moves to position when cue activated) In which cue is the fault likely to be? Do I need to delete the cue and re-enter, or is there another fix? Many thanks.
  18. Earlier
  19. Ever since acquiring my Frog 2, I noticed that with the Dockhouse (Capture) Demo Presentation show file for ZerOS (available from Zero 88 here), it is of course a .zos file. The change from .isf to .zos for show files was made in ZerOS 7.9.8, a version of which is after 7.8.2.39 (the last supported software version for Frog 2) meaning Frog 2 only loads show files saved with the .isf extension. This means my fellow Frog 2 users won't be able to use the Capture Demo File for learning or having a play/experiment, so I have "converted" the .zos show file to .isf in order to be compatible with Frog 2. I imagine the audience for this won't be too large anymore since I feel Frog 2 popularity has died down significantly, but I'm posting this as a public resource in case it is of use to anybody who still uses a Frog 2 or a console on a version of ZerOS before 7.9.8. When loading in the show file, you'll be told it was from a Frog 2 and that some data won't be loaded. There shouldn't be any reason that some data won't be loaded with the way I've done this, but if you are loading this file onto a Frog 2, UDF 1 (User Defined Fader) will have a stored state on it. If loading this onto a different console type without UDFs (e.g. Solution), this should be transferred onto playback/submaster 1 (theoretically). It is also worth noting that this .isf show file is only within the limitations of Frog 2 - meaning the other higher universes found on the .zos version won't be seen or usable (Universe 5 & 6). The attached show file loads with the newer ZerOS skin if on Frog 2 - other consoles have that skin by default regardless, to provide a familiar user interface appearance to the other consoles people may have used with capture in comparison to the light grey and green classic theme on Frog 2. I have tested the .isf file with the Zero 88 provided Dockhouse 2022 file designed for the .zos version and it does work correctly. Anyway.. here's the show file, hope it is of use. Z88 Capture Dockhouse v7-8-2-39.isf
      • 1
      • Thanks
  20. Hello Kisi When you start creating a fixture file with Fine or 16 bit resolution, select Pan then select 16-Bit on the bottom line, then when you select OK, CH1 will be Pan and CH2 will be Pan fine. Then when you select CH3 and select Tilt, the Fixture creator will put Tilt as Ch 3 and Tilt Fine as CH4
  21. No worries, give me a few minutes. Edit: Send to your email Best, Charlie
  22. @Charlie Newman Can you please send the fixture to my email kim@eventon.no Thanks best regards Kim Simensen
  23. @Charlie Newman I know. We tried and the "fine tilt" and some other stuff its missing there.
  24. Thank you for this information, it definitely sounds like ZerOS Watchdog kicked in while loading the show file. It would have displayed a list of registers and then also a stack trace. Archie
  25. It was a crash dump (like a Linux shell window?) on the monitor. but then the monitor froze and i rebooted.
  26. Hi Paul, Saving the setup within the show file as well theoretically shouldn't cause any problems. If you can recall - when the console crashed, was it a black screen with a load of white text (ZerOS Watchdog kicking in) or did the console just completely freeze, preserving monitor output too? Let me know how you get on later with LF48TEST1.zos, it has a few things disabled/removed to see if anything in the show file itself is crashing the LF48. One of my theories for this was that because the Leapfrog 48/96 came with 2 DMX universes as standard, with an optional upgrade card while the Solution comes with 4 universes straight from the factory, that ZerOS was trying to index a universe from the Solution (3 & 4) that didn't exist on the Leapfrog when loading in the show file (if the optional upgrade card for 2 more outputs isn't present). Hence, U3 and U4 are disabled in that show file. However, it is just a theory and could be wrong. It's all about experimentation to see what works! I look forward to hearing from you, thank you. Archie
  27. Hi @kisi, welcome to the forum! I should be able to do this this evening for you, however you're also able to do this within the desk itself under "SETUP" -> "Add New Fixtures" -> "Create New Fixtures" Please let me know if you have any questions. Best, Charlie
  28. Need help to build a fixture file for my new light. Name of the light is Maverix - BSW 350 Can someone help me, I use a Vari lite FLX S24 console attached is the dmx chart. Best regards Kim Simensen Maverix-BSW 350.pdf
  29. Hi Archie. I will try later. I wonder if, when i saved, i saved the showfile and setup, rather than just the showfile. Thanks Paul
