- Past hour
कुकू एफएम में शिकायत कैसे करें-हेल्पलाइन नंबर 07749+91+3371
latajjHoeua replied to latajjHoeua's topic in General Discussion
कुकू एफएम की वेबसाइट पर जाकर उनके ग्राहक सेवा +91↘77499↙13371 → संपर्क का विकल्प देखें। वहां पर आप ईमेल या Whats___app (07749~91~3371) के माध्यम से अपनी शिकायत दर्ज कर सकते हैं। -
latajjHoeua started following कुकू एफएम में शिकायत कैसे करें-हेल्पलाइन नंबर 07749+91+3371
latajjHoeua joined the community
ETA if my instructions are not clear, Edward documented the process in this paragraph (although again for FLX series). As he says, you might need to Track Forward, depending on where your cue is programmed/when you do the Update process: -
Davidmk started following Bug and crash on flx s48 - ZerOS 8.0.0
kgallen started following Stopping Movers after a cue with an effect running and Bug and crash on flx s48 - ZerOS 8.0.0
@RJP @DMH @Alexandre Honestly, you'd have to try it. I don't think there were major database changes from 7.14.3 to 8.0, but support for relays was added. If you didn't use the new features in 8.0 like the new channels/playbacks/groups/palettes, then maybe there is a chance. Save your showfile and try it. Review the outline of the changes on this page. Other users may comment if they've tried to go backwards from 8.0 with a showfile.
Hello everyone, I open a topic here because I didn't receive answer from support email, and maybe people here have somes clues 🙂 (I thinks my pro isp blocking zero88 email) Since the last update, I’ve encountered a high severity bug affecting some playbacks, which causes the console to freeze and always crash. I reproduced the issue using Phantom OS on PC — the software crashes there as well. The problem seems related to specific playback settings, particularly the "Move on Dark" and loop playback options. Please find attached the error dump file and my full showfile. You can easily reproduce the crash by accessing Playback 7 and playing it. Is it possible to downgrade the firmware without losing compatibility with features I’ve used from version 8.0.0? Thanks in advance for your help. Best regards, Alexandre Error Dump file : https://drive.google.com/file/d/1Q3FHoJ1W4sxAgfwgfgq81dUKGNM2UEXG/view?usp=sharing fin-juin-2025-06-01-02.zos
To clarify, for Update you need to get up the options box to turn off SmartTag. For FLX this is press and hold the Update key. -
Hi @Worcester RGSTech This is a common gotcha on ZerOS consoles. I don’t know the exact syntax on Solution, sorry, but assuming you have a fairly recent ZerOS then you need to Update the cue with Effect Off with SmartTag turned off. 1. Select the fixtures of interest 2. [No Effect] 3. [Update] 4. Turn off SmartTag 5. Tap the Playback button holding that cue Almost certainly the blackout cue was recorded with SmartTag on in which case it doesn’t record the Effect Off instruction, just the fixtures going to intensity 0. This means your fixtures keep dancing when they are dark. Yep Jon and Edward are gone but there are user-folk on here who can still help you. -
If I record a cue running an effect in which movers are moving on a preset pattern, figure of 8 for example, does anyone know if there is a way of stopping them moving whilst blacked out in the next cue? I have tried multiple ways and the only successful method seems to be to record them in a position at a very low intensity when stopping the effect. I don't want them moving around whilst blacked out, especially as their subsequent cue will likely be in a static position as a special. I don't doubt that not so many months ago Edward or Jon would have been on with a solution. Alas we seem to have been hung out to dry these days.
Johnbel74 joined the community
@DMH@RJP The SPAM postings seem to be on the increase with over 40 in last 24 hours plus others highlighted but still on the forum. Please can some trusted forum members be promoted in a way to allow removal of these posts?
Hi @SoleJan Blue UP to the sky, green DOWN to the grass. (Blue means that channel intensity went up, green it went down.) White, it's a blocking value, purple it's tracked. Red from the programmer (highest priority), yellow for some other controller. Red background is Parked. Grey background (for a short time) is moving on dark. They're all here: https://www.zero88.com/manuals/zeros/desktops-windows/output-window#colours
Hey again, little thing to ask again about the Monitor. (btw, got Remote working via Emulator thanks for providing the link) In the attached file 5 of the Briteq Theatres intensity are marked blue while one is green. Is that to indicate a change from the previous Cue? My first thought was, it indicates dynamic change of Int. in a Cue i.g. like a ramp up effect, but the theatres dont have any like that on in the Cue. This is no problem but im interested as for why this is. Jan
