  1. Last week
  2. Hi Ian, That's great news, glad to hear you got it sorted. Have a good day, Archie
  3. Archie, Many thanks for your reply. After reading your reply above, I swapped from selecting all the fixtures and applying a default, and stepped through all fixtures one by one and applied the default also fixture by fixture. As I did I could see some colour information that way. All working now - fades occur as expected - some blackout cues had to be rebuilt - but overall we are now working. I've learnt something new - I had never checked or tested the default settings before, and I am delighted it now works as I expect it to. Only change to workflow is creating new scenes I now have to select a fixture and chose the colour I want first, as of course the intensity comes up black now. But easily manageable. Reading the old threads led me down the path of 'Select all' Spin all colours to '0' 'Record' 'Home' 'Defaults' - which was not applying default to black on all fixtures. Changing to 'Select Fixture 1' 'Spin all Colours to 0' 'Record' 'Home' 'Defaults', and then 'Fixture 2' 'Spin all Colours to 0' 'Record' 'Home' 'Defaults', and so on was the solution. Thanks again Ian
  4. Hi @Ian_p, Please could you upload your showfile here? We may then be able to figure out if it's a problem with the fixture itself, or if the fixture has some funny channel on it in the profile causing this erratic flashing behaviour, thank you. The previous 'Edit Fixtures' window to see and change defaults of fixtures was removed in ZerOS 7.9.3 in favour of the new Fixture Schedule section of SETUP. To see a fixture's defaults, you could select the fixture(s) and page through the different attributes and see each individual parameter value on the internal touchscreen of FLX S.
  5. Good afternoon @Richard Elv, You can purchase a Phantom ZerOS Unlock Dongle from one of the distributors, or from here on StageGear. For outputting DMX with Phantom ZerOS, the Unlock Dongle must be plugged into your computer. If it is unplugged, DMX output will stop until the dongle is present again. Regarding methods of actually getting DMX out of your computer from Phantom ZerOS, you have two options. The first, is to output over the network using protocols such as ArtNet or streamingACN. The second, using a USB to DMX device (ones which support the ENTTEC protocol). Personally, I recommend the ENTTEC DMX USB Pro, which is generally considered to be a very high quality device and can be configured straight from ZerOS in SETUP -> Devices. Each of these devices will output one full universe of DMX. When running Phantom ZerOS as a FLX, you have access to 16 full universes of DMX (8192 DMX channels) over 64 patchable universes. If you're already used to using FLX, using a Phantom ZerOS Unlock Dongle will be ideal as it will give you the front panel you are already familiar with - just virtually. This can be used with a touchscreen, along with the external monitor for multi-touch functionality. Yes, the ZerOS Wing can be used with Phantom ZerOS running on a PC via USB as if you were using it with a physical console, therefore you will be able to use it across both your FLX and Phantom setup. Using a ZerOS Wing is the best option to give you more faders at one time. I hope this helps, Archie Bonjour @Richard Elv, Vous pouvez acheter une clé de déverrouillage Phantom ZerOS auprès de l'un des distributeurs ou directement sur StageGear. Pour la sortie DMX avec Phantom ZerOS, la clé de déverrouillage doit être branchée à votre ordinateur. Si elle est débranchée, la sortie DMX s'interrompt jusqu'à ce qu'elle soit reconnectée. Pour récupérer le signal DMX depuis votre ordinateur avec Phantom ZerOS, deux options s'offrent à vous. La première consiste à utiliser le réseau via des protocoles tels qu'ArtNet ou streamingACN. La seconde, à utiliser un convertisseur USB vers DMX (compatible avec le protocole ENTTEC). Je recommande personnellement l'ENTTEC DMX USB Pro, généralement considéré comme un appareil de très haute qualité et configurable directement depuis ZerOS dans le menu CONFIGURATION -> Appareils. Chacun de ces appareils génère un univers DMX complet. Lorsque Phantom ZerOS est utilisé comme FLX, vous avez accès à 16 univers DMX complets (8192 canaux DMX) répartis sur 64 univers patchables. Si vous utilisez déjà FLX, l'utilisation d'une clé de déverrouillage Phantom ZerOS sera idéale car elle vous permettra de retrouver virtuellement le panneau avant que vous connaissez déjà. Vous pourrez l'utiliser avec un écran tactile, ainsi qu'avec un moniteur externe pour une utilisation multitouch. Oui, la ZerOS Wing est compatible avec Phantom ZerOS installé sur un PC via USB, comme si vous l'utilisiez avec une console physique. Vous pourrez donc l'utiliser à la fois avec votre configuration FLX et Phantom. L'utilisation d'une ZerOS Wing est la meilleure solution pour disposer de plus de faders simultanément. En espérant que cela vous soit utile, Archie
  6. Bonjour. Merci pour cette réponse claire et complète. Où peut-on acheter une clé de déverrouillage pour zérOs phantom et un d’ongle usb/xlr compatible en France? Je suis professionnel. Est ce que le Wing est utilisable avec zerOs phantom comme si il était raccordé sur Flx? Pour être complet dans mes demande j’ai besoin de temps en temps d’ėtendre ma Flx avec quelques Fader supplémentaires et je comprend d’après vos explications que le mieux c’est le wing. Mais j’ai également besoin bien plus souvent d’une autre console indépendante. Je cherchais une solution pour éviter d’avoir à multiplier les produits. Un grand merci pour vos réponse. cordialement Richard
  7. All, I've read all the threads I can about default settings - but I'm still having issues with an intermittent flash to white when fading between cues. Worse if the fade is more than a second. FLX S24, V8 software, using playback 0 in a theatrical cue stack. All conventional dimmer lanterns are on page 1 and 3 - no issue with these. All LED fixtures are on page 2 for convenience. I select all by holding first channel button and pressing the last and then I can see RGBW on the inbuilt screen - moved these to 0, press 'Record', 'Home', 'Default'. Only it doesn't seem to work. Still getting the flash - but only sometimes not every fade which baffles me. Do I need to set default fixture by fixture...? Is there a way to look at the config of a fixture and see what the defaults are? At present I seems I can only overwrite the default - without seeing its present state. Any assistance would be gratefully received! Cheers Ian
  8. Earlier
  9. Hi @Richard Elv, Welcome to the Zero 88 Forum! Ultimately, it is highly recommended to use a ZerOS Wing to expand the available faders that can be used at one time on your console. However, using another console such as the FLX S24 is possible, but quite limited in comparison to a Wing. For instance, with this method, when you bring up a fader of a fixture on the FLX S24, it won't automatically be selected on your main FLX console, whereas on a Wing it interacts with the console and does select it automatically (depending on the 'Auto select channels' setting in SETUP -> Settings -> Operational -> Auto select channels). You also won't be able to do record, delete, SETUP + Tap playback button etc using the method described below, DMX Input. For using a FLX S24, you will need to configure one of your DMX output ports on the main FLX to be a DMX input instead. To do this, go to SETUP -> Universes, and tap 'DMX in' on the DMX output you wish to be a DMX input instead. On the FLX S24, you can patch in a bunch of dimmer channels (I recommend patching in the maximum available on ZerOS 8.0, which is 96). Then, connect the first DMX output port on the FLX S24 to your defined DMX input on the main FLX. You will need an adapter for the correct XLR connector to link the consoles together as they are both female XLR outputs. After this has been done, you now have a 'DMX In' column in your Fixture Schedule within SETUP. This lets you define a DMX In address for each individual fixture patched in, so when the console receives DMX data from the defined DMX input port (e.g. I raise channel 1 on the FLX S24 which has DMX address 1 -> FLX receives that data -> Fixture 200 in the FLX has a DMX input address of 1 -> Fixture 200's intensity raises), it will respond as configured. For playbacks, you can set a playback's DMX input address via SETUP -> Triggers -> DMX In. From there, you can tap 'Add' to add a playback to configure ready for DMX Input. In the example below (image attached), I have set Playback 1 on a FLX to be raised and lowered with DMX input address 25 coming from a FLX S24. I have done this so my first page of dimmer channels on the FLX S24 control fixtures, whereas the second page controls playbacks. (1-24 fixture control, 25-48 playback control). If you wish to use the Channels/Playbacks switcher button on the FLX S24, you could set up 96 dimmer channels (4 pages of dimming), use the first 72 (3 pages of dimming) as fixture control, but individually record each of the remaining 24 dimming channels at full as a playback each (playback 1-24), and on the main FLX you set the DMX Input address for each of your playbacks to the last page of dimming on the FLX S24. If you require control of more than 24 playbacks, you could go back further than the last page of dimming and use some of the third page too of the FLX S24. Overall, the ZerOS Wing has been designed to interact with the FLX or any other ZerOS console, and was produced for the reason of adding extra faders that can be used at one time. Using DMX Input is rather limited, so my recommendation is to use a Wing. But, I hope this helps, and if you have any further questions please don't hesitate to ask. Apologies for not translating, I figured if I did then this message would be colossal. Archie
  10. Bonjour Est-il possible d'étendre les fadeurs sur Flx avec une autre console s24 par exemple ? Avoir les mêmes fonctions qu'un Wing mais au moyen d'une S24 une fonction maître esclave cordialité Richard
  11. Worked like a charm, many thanks.
  12. I’ve got one of these. Make sure you are on a modern version of zeros and search for the showtec act fresnel 150 RGBAL. That is a library fixture. You can then edit it and rename to the act profile as it has an identical DMX patch. Let me know any problems. Link to the manual below if you’re not sure how to edit and rename fixture. The only thing you need to change though is the name. Also don’t use RDM or rigsync as that will complicate things. https://www.zero88.com/manuals/zeros/patching/add-fixtures/edit-export Brian
  13. I'm trying to install this fixture on my FLX S48, but can't seem to find it on the ZerOS library. Does anyone have or know where I can find the patch? I'm not experienced enough to manually install it myself.
  14. Archie D
    Chauvet P7
  15. Desgeorge
    Chauvet P7
  16. kgallen
    Chauvet P7
  17. kgallen
    Chauvet P7
  18. Desgeorge
    Chauvet P7
  19. Hi @DSUK73, Welcome to the Zero 88 Forum. Using a Phantom ZerOS Unlock Dongle unlocks the maximum amount of channels available for the fully upgraded console you are emulating (e.g. emulating a FLX will give you 8192 channels = 16 universes, emulating a Solution will give you 2048 channels = 4 universes). Any USB to DMX device that supports the ENTTEC protocol should work with Phantom ZerOS, I personally use the ENTTEC DMX USB Pro and have two of them. Each ENTTEC DMX USB Pro device will output a single universe of DMX. You can, of course, output DMX over Ethernet via your computer's network port for less cabling out of your PC if you have an Ethernet gateway. Once the USB to DMX device is plugged in, it can be configured in SETUP > Devices. This allows you to set the universe being output on that device, output rate, etc. Purchasing an Unlock Dongle is a great investment and I highly recommend it. I hope this helps, let me know if you have any questions. Archie
  20. I'm considering buying an unlock dongle for Phantom to use my laptop to control our dimmers and also to play around with light fittings that aren't 'stock' and need specific profiles creating to allow them to be used in shows. I've been looking at various sites and seen references to Phantom outputtting via Ethernet and other sites suggesting it can be used with a USB connected controller. What experience do people have with using a laptop and an unlock dongle via either Ethernet or USB and what device did you use to hook into your DMX infrastructure (dimmers, fittings etc.).
  21. I still plot some of my shows on our FLXS24 treating the RGBW pars as 4 discrete channels. I know this is not the normal method, but it works for me. It enables me to add a little of one state or of a colour from one lamp or more at the speed that I want, and then fade it out again leaving everything as it was; I can add a colour chase or a highlight "sparkle" chase for a few seconds or for one complete item, fading it in over the top of the base state at the time, and fade it back out.
  22. Bedien je licht als een pro Leer alles over de FLX S24 en S48 consoles: veelzijdig, compact, compleet én betaalbaar. Van slimme programmeertrucs tot creatieve showdesigns. Of je nu al jaren licht draait of net begint. Wij zorgen dat je straks lichttechnisch onverslaanbaar bent. 25 maart 2026, 09.30 – 16:00 uur (lunch inbegrepen), Locatie: Moonbears HQ, Moskesbaan 8, Breda, NL https://moonbears.eu/events/vari-lite-flx-training/
  23. How can i Copy some FX to another fixture same type. No FX palette was created. The FX is a combination of FX....
  24. Ah - after re-reading my post I realised I mis-interpreted part of your post! I apologise. But yes, that would definitely work loading the FLX S show file into Phantom ZerOS and editing it while emulating a FLX console to create a user macro. The only thing you'd run into is once loading the show file into the FLX S, re-saving it and then needing to create another chase later down the line, you'd need to re-construct the user macro again on Phantom as it originally won't have been loaded in to the FLX S. If the chase is in the same arrangement as before, I suppose you could copy the chase and just track through a colour change of the fixtures in each step.
  25. Yes make sure you produce the chase with the macro before transferring! 😅
  26. Just for clarification, when loading a show file containing User Macros into a FLX S console, they will be disregarded and not transferred over. Hope this helps. Archie
