Haytech
Everything posted by Haytech
  1. Hi John, sp is right - you have to buy a SMPTE/MIDI/CAN upgrade for this function of the frog range. see Infos on Frog range here ...
  2. Hi sp, please mind that if you use the 'Beamshape LTP' values for generic lights it will be very tricky to dim this lights.
  3. Hi To me it seems, that some of us are little apologetic to serve their information on www, maybe they are critic to share because it can be abused very easy. I´m sure Zero88 won´t share any regristration data. The Frog creators and users are very honest...
  4. Hi, this error has done near anyone on this forums but the supporters. Typical starting problems ...
  5. Hi, Vote me in for one of the northpole cool "ICE88" ones I love your suggestion Ice but you should ivestigate some more time on the right side of ICE
  6. TIA Ice !
  7. Hi, How do I program a chase including some fixtures to change colours without storing the brightness / beamshape / position data ? My desk works already in 'partial' mode
  8. You´re right Laubfrosch, You can have a colour change chase with movement effects in them, without bothering the movement shape. Very Cool indeed. 8)
  9. Can I run a certain effect i.e. ellipse x 50 / y50 s 5 / through a whole chase ? have say step 1 change colours to open / red even then step 2 changes color open/ red odd ?? without starting the movement anytime ? PS. this is more a How Do I question I know , but it arises by reading this thread
  10. Hi, there isn´t a step option on the effects generator. You can also have nice movement effects without the effect generator ! remembering good old times storing every movement in a chase ! If you want a certain effect set the fixture positions press chase on a free memory i.e 983 be sure every scan you want to store is 'tagged' then press program set pos2 on chase step 2 pos3 on chase step3 and so on then have a play with chese modifieres:
  11. The badgers are back
  12. Hi, I suggested "speed groups" before elsewhere in forum ( I´am to lazy to have a look ) As DMX256 suggested before to have a pick/copy speed option it would be nice to have a a bounch of speedgroups on submasters.
  13. Seemed to be a problem with LTP Fade on chase try to set your Chase to LTPFade=Snap and then decrease MSpeed to ie. 120 on step2 and 3 voila your movers fade throu the audience once.
  14. Indeed SP´s right check your wheels first. If they react as they should do you should try to "reload" your fixture file to the desk please be sure that entire show is saved on disk. Then delete all concerned fixtures and reload it from a fresh downloaded fixturefile - this helps me a couple of times hitherto. If it is your own fixturefile that is responding dull, then please be sure not to set up the "wheel groups" in "Fixture Type Editor" the desk sorts it´s recommended values to the wheels itself. Hope this helps you !
  15. After 100m 16mm² cable on a single phase 13A ? - the wireresistor is so high that in this case nothing should work proper, on your stage. I have had a similar event last friday night. A 24 KW lighting rig plus 10KW Audio on one 32A 3 phase with about 130m cable inbetween us and distro. They connected a automated scooter to the same distro despite we were there first and said them not to put any more on that box. Thats why every time the automated scooters began to run ( remember high inductive loads) my lights went down the 50% about 100V powerloose on phase 1 & 3 my fixtures dont like blackout like these so they decided not to work proper the whole evening. All in all it looked worse but nobody noticed it despite me. At the end of the day there where a couple of frays. Buisness as usual but no security service ! - We take down our set at 7:00 o´clock in the morning after all people was gone. Last but not least it began to rain on the tick we opend the lorrydoors.
  16. Hi I said before elsewhere here in forums that I´m prepared to pay 500€ for additional WYSIWYG environment without hardware ! So vote me in to have a WYSiWYG
  17. Ice, indeed a very nice vagary but how do you stop this chase running ? when a colour chase steps ie. open / red, call a pallet maybe blue/ yellow the chase runs all the time ? I sugesst that such colour / gobo chasers can be stored on a pallette !
  18. Today we found out, that it´s worse to work without power 8O So my sugesstion today: a independend power distribution for each desk
  19. To be honest, how does that work proper ? There is no question yet why you are "Software Guru"
  20. You´re right SP but it should be a "dimmer curve" definition for all generic channels. A sudden limitation of channel output to 90-95 % until flash don´t saves lamptime when lamp can run @ 100% by channel fader or have say a fast chaser. The only thing to do here is to set a lamp preheat and a topset which can set by nearly every professional dimmer.
  21. I agree to Laubfrosch ! Sound´s he earns more Beer we could produce in Bremen
  22. Wow - amazing I didn´t see a moveinglight in a church before I see that there is a use for If there is a play / show on church but on normal ceremony. In these parts parochial church councils aren´t very modern - they are little way oldschool.
  23. hopefully you don´t mean "deafly" peple rather than a star sarch casting in the first 2 hours
  24. in my mind I wouldn´t "play" with the church lights, but to be honest I´d never seen a british ceremony. Just remember that some people of the crowd maybe little old and myopic if not dawnblind - keep the lights bright enough that all of the crowd can read their choir book. Decrease it if something happens near the altar like nativity play, christening, Gregorian chant, whatever needs the attention of the crowd. I´am sure you can ask some people after ceremony about their feelings with the lighting.
  25. Had had to much beer last night
