LIGHTING Posted December 2, 2024 Report Posted December 2, 2024 Buonasera Il lato destro della mia consolle FLXS24 non funziona più correttamente, è per poter lavorare devo agire tramite il touchscreen del tablet che ho collegato tramite l’app ZeROS Monitor qualcuno può aiutarmi a capire cosa sia successo e se si può calibrare il touchscreen della FLXS24? grazie
Charlie Newman Posted December 2, 2024 Report Posted December 2, 2024 Heya! What do you mean by "it is no longer working correctly"? If it is similar to this post, it could be a software version, which version are you currently on?
kgallen Posted December 2, 2024 Report Posted December 2, 2024 @Charlie Newman S24 doesn't have a DVI-D monitor port (only S48 and full FLX). However I agree it's not clear what "right side" is, if the console is still otherwise full operable from the Monitor App. @LIGHTING can you clarify please? Is the console fully working except for the internal touch screen? I understand internal touchscreen failures are uncomfortably common on S24. If yours has failed and it's still in warranty (up to 3 years old), then you need an urgent service request entering with your supplier. If the console is over 3 years old, then Zero88 might still help but I've also heard that the touchscreen is a standard component used with Raspberry Pi boards, but just with some extra mounting parts that could be transferred over. However I have no other knowledge or experience of this.
Charlie Newman Posted December 2, 2024 Report Posted December 2, 2024 6 minutes ago, kgallen said: @Charlie Newman S24 doesn't have a DVI-D monitor port (only S48 and full FLX). Ah yeah apologies, again me being used to the fullsize haha
