DALX Posted August 10 Report Posted August 10 During a lighting workshop last week I was asked can you copy one cue to multiple cue locations at the same time to speed up plotting. I tried Copy To 5.10.15.20 as a syntax and it copied a cue to cue numbers 5, 10, 15 and 20 using the period . as a separator. I have tried to find this in the ZerOS handbook but have not found it. I know it works but I was hoping to find a description to see more Copy syntax options ? Can someone point me in the right direction please ? Quote
Archie D Posted August 11 Report Posted August 11 Hi @DALX, Slight query - I can't seem to replicate your copying procedure using syntax. Typing the syntax to copy cue 1 on playback 1 to cues 5, 10, 15, 20 gives invalid syntax at the second period (1/1 Copy To 5.10. <-) as only one decimal point is allowed. This means cue 1 can only be copied to cue 5.1, disallowing the period to be used as a separator. Alternatively, using the copy window (Z/Shift -> Copy).. From 1 To 5.10.15.20 returns a new cue numbered 5.1. ZerOS is interpreting my entry as a point cue here too rather than multiple cue numbers, given that point cue numbers can only be up to 2 decimal places. The second period invalidates the further numbers anyway. In ZerOS, you can copy multiple cues to a single cue number. That single cue number acts as the starting number. For example, copying cues 1>5 to cue 10 will create cues 10 to 15. Copying cues 1+3+5 to cue 30 will create cues 30, 31 and 32. In the Copy Window, only the 'From' input box allows + and > whereas the 'To' input box doesn't. Please could you elaborate further on what you're doing to achieve this? I might be missing something. Many thanks Quote Archie - Student Student of lighting design & operation Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Jester ML24, Juggler (x3), Level 6, Level 6 DMX, Level 12, Level 18 Plus, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Lightmaster 1200 (MK1), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, 4x Zero 88 Focus 650 Pebble Convex's, Linebacker, Demux 48 (x2), Strand LX
DALX Posted August 11 Author Report Posted August 11 Thanks for looking. My desk is at a school so tried it with Phantom ZerOS without success, will try it on the desk tomorrow. 1 Quote
