Jimbob Posted October 17, 2010 Report Posted October 17, 2010 Hi All I have a show coming up that is going to be using Varilite Movingheads and I was hoping someone could instruct me on how to patch them into the Orb. I am using 48 conventional fixtures which is connected to universe 1. I know you can go into the menu and and and fixture and select manufacture and quantity. But how do I get the Varilites to start DMX address after 48 ? Also do these get connected into the second Universe ? I have tried to read the instructions but am a little confused. Aplogies if its a simple job. Jim
Jon Hole Posted October 17, 2010 Report Posted October 17, 2010 Hi Jim, In Setup, click the Patch Wizard. This gives you a step-by-step method of patching fixtures which takes you through adding the DMX address and assigning them a fixture number (the number you type into the desk to control that fixture) etc. Hopefully this will be an easier method to patch. If you have any more questions please get back in touch! Jon Hole linkedin.com/in/jonhole
Jimbob Posted October 28, 2010 Author Report Posted October 28, 2010 Hi Jon Thanks for that. That made it easy ! Jim
