jesterfish Posted January 29, 2012 Report Posted January 29, 2012 Hi. just got back from gig using a friends fat frog being familier with setting up submasters with basic scenes chases etc i got a bit annoyed when i set up a forward sweep i ie: scanner beams start at back travel forward and then back and repeat ( y axis ) i found that the beams would go 2 one way 2 the other when i entered the speed option ( offset at zero) also set to Relative mode. in manual tilt mode all scans set the same ( no reverse tilt or pan ) im assuming there must be a preset that needs altering as my f/frog will do a forward sweep no problem thanks jesterfish
Jon Hole Posted January 30, 2012 Report Posted January 30, 2012 Hi Jesterfish, Did you go through each fixture individually and check the offset was 0? Did you try putting a 50% offset on the two that were going the 'wrong' way? Jon Hole linkedin.com/in/jonhole
jesterfish Posted January 30, 2012 Author Report Posted January 30, 2012 HI . thanks for reply i will try that on wed i had noticed that offset was input at 10 % increment and zeroed them before start also the offset reset itself when trying to reprogramme same effect could this be a preset done with the fixture editor ? although i think this unlikely as fal 2000 are in the fixture library as a choice so no need to set a custom profile thanks for your reply. Rich
