Weir69 Posted November 24, 2015 Report Posted November 24, 2015 Hi all, I'm doing a show in a venue that has a Jester ML 24. On the rig there are 2 Chauvet Beam LED 350s that are not patched into the console. Also there does not appear to be a profile for said fixtures under Chauvet category even though a quick internet search says that there should be one. Does anyone know if there is? Also if not I would greatly appreciate if somebody could make one up for me, I've not used the software before and have very limited time in the venue so I would like to be sure it will work. Thanks!
kgallen Posted November 24, 2015 Report Posted November 24, 2015 Can you point me at a manual and I'll have a go. Chauvet have a "Beam" and a "Spot". You say "Beam" but then "Profile" which means I'm not sure which model you really mean. This (Beam LED 350): http://www.chauvetlighting.co.uk/products/manuals/Intimidator_Beam_LED_350_UM_Rev3_WO.pdf or this (Spot LED 350): http://www.chauvetlighting.co.uk/products/manuals/Intimidator_Spot_LED_350_UM_Rev8_WO.pdf ...or something else entirely!
Weir69 Posted November 24, 2015 Author Report Posted November 24, 2015 Hi I mean the Beam 350 LED. By profile I was meaning the file that the console reads. Thanks alot
kgallen Posted November 24, 2015 Report Posted November 24, 2015 Wow, that was a busy one. Give this a go... Regards, Kevin Chauvet_Beam_350.ift
Weir69 Posted November 24, 2015 Author Report Posted November 24, 2015 Great! I'll give it a shot tommorow and let you know how it goes. Thanks again, Hamish
Weir69 Posted November 25, 2015 Author Report Posted November 25, 2015 Thank you, tried today and it appears to work perfectly. Sorry I also should have told you I was using them in 14channel configuration.
kgallen Posted November 25, 2015 Report Posted November 25, 2015 Cheers, Hamish, glad it worked ok! Regards, Kevin
