B3n Posted September 17, 2018 Report Posted September 17, 2018 Hello , I want to know if it is possible to manage the speed of effects with a fader? flx does not have effects with music? Thank you ;-)
Edward Z88 Posted September 19, 2018 Report Posted September 19, 2018 Hello, If you have programmed an Effect to a playback, you can enable Fader Controls Effect on that playback. This is done in the playback settings by holding SETUP and tapping your effect playback, and choose "Effect" from the Fader Controls... buttons. The Effect speed and size will then be scaled by the fader. Hope that helps, any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
glenn suys Posted November 19, 2018 Report Posted November 19, 2018 Is It possible to create a 'master' fx fader ? like the Chase speed tap button ? That you can connect mulitple cuelists with FX in it to a single master fx speed fader ?
Edward Z88 Posted November 19, 2018 Report Posted November 19, 2018 Hi Glenn, There is not a master effect rate control, however Speed Override will control the rate of your effects. Speed Override is found on the second encoder wheel by tapping Z/Shift, and can be used to slow down or speed up the running effect on the currently viewed playback. Therefore to choose which playback you wish to control, hold VIEW and tap your playback's button. You can also configure Speed Override to be controlled by a fader as well as an encoder, by holding SETUP and choosing an empty playback button. You can then select Speed Override from the options. Hope that helps, any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
