Tva-events Posted November 23, 2018 Report Share Posted November 23, 2018 Hi is there a way that a fixture ignores the grandmaster ( Strobe in black out ) thanx Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 23, 2018 Report Share Posted November 23, 2018 Hello, Do you always want this strobe to ignore the Grand Master? If so I would recommend editing the fixture, and remove the Intensity parameter. The Grand Master will always effect fixtures with intensity parameters. If you have a few fixtures that you don’t want to be effected by the Grand Master, instead you can use the Inhibit function. To do this select all fixtures that you DO wish to have total control over, turn them on to full, and record them to an empty playback. Enter the settings of this playback by holding SETUP and tapping this playback’s button. Under intensity mixing choose Inhibit and click OK. This playback will then act as your Grand Master. Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Tva-events Posted November 24, 2018 Author Report Share Posted November 24, 2018 Ok thanx ! Quote Link to comment Share on other sites More sharing options...
