francocampo Posted January 23, 2019 Report Posted January 23, 2019 Good morning, if possible can back on the playback with varius cue, for example in my playbabk there are 3 cues, with botton under fader if possible go next cue, if possible back the cue? Excusme for my bad English, thank you for response. Best regards
Edward Z88 Posted January 23, 2019 Report Posted January 23, 2019 Hello, 7 minutes ago, francocampo said: if possible can back on the playback with varius cue, for example in my playbabk there are 3 cues, with botton under fader if possible go next cue, if possible back the cue? Yes, it is possible to Go back through a cue stack, as well as Go forwards. The button under each playback can have 2 different behaviours, one for when it is pressed, and a shifted function for when the button is pressed with the SHIFT key held down. You can therefore configure pressing the playback button to Go forwards, and holding SHIFT and pressing the button to go back. To customise this hold SETUP and tap the Playback's button. At the bottom of the Settings window is a button function option. If you hold SHIFT, you will see the red stripe move from Go (Fade), to Go (Snap). With SHIFT held down, choose "Pause" from the options, release the SHIFT key, and then click OK on the settings window. Now, when you hold SHIFT and tap the playback button, it will act as a Pause if a cue transition is in progress, or a Go back if the transition has completed. You can read more about Playback Settings here... http://support.zero88.com/1077997011 Hope this helps, any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
francocampo Posted February 2, 2019 Author Report Posted February 2, 2019 Dear Edward, I thank you infinitely for the answer and I wish you all the best.
Edward Z88 Posted February 2, 2019 Report Posted February 2, 2019 No problem at all, if you have any further questions just let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
