Ofe Posted April 30, 2019 Report Posted April 30, 2019 Hey I’ve bought the FLX 48s a year ago. Already in the beginning i sometimes noticed that to console randomly selects channels after i selected the one that i was trying to edit. This problem is now getting worse. Last weekend i couldn't deselect a channel. I tried to push the button several time but i lid up immediately again. So i moved the fader of this channel just a little bit and then it worked again. Can you please help me with this issue? I hope this is not a hardware issue. Thanks a lot, yves
Edward Z88 Posted April 30, 2019 Report Posted April 30, 2019 Hello, Sorry to hear this. This is not a hardware issue. When "Auto Select Channels on Fader Move" is enabled, the channel selection is quite sensitive, and so the slightest fader movement will cause the channel to select. To prevent this from happening, tap SETUP -> System Settings -> Auto Select Channels on Fader Move -> Disable. You can then manually select the fixtures using the channel buttons. The sensitivity will be reduced in ZerOS 7.9.5, which will be the next software release for FLX S. If you have any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
