van den abbeele Eric Posted May 15, 2019 Report Share Posted May 15, 2019 Hello, I have questions about the aspect of the effects. 1 / For some light consoles (Chamsys, GrandMa, etc.), the aspect of the effects is a great strength. We can quickly do something that can be thrilling for an audience ... The effects can as much play on - the movement of a projector - Color change - gobo change - play on the opening of the Zoom, - opening prism closure, etc .. - and several actions grouped with some ease ... . For the FLX, this part will be able to evolve to increase during a show the capabilities of animations? 2 / if I program imagine in the "playback 1", a sequence of various motions in chase version (40 cues for example), can I recall this playback in a master cue playback and if so how to proceed? Thank you for your patience to answer us and see you soon, Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 16, 2019 Report Share Posted May 16, 2019 Hi Eric, The 32 effects on FLX currently adjust Intensity, Position, Colour, and Beam. In ZerOS 7.9.5, this will be increased to 45 auto-effects, including improvements on the existing, and many new effects. On 5/15/2019 at 12:35 PM, van den abbeele Eric said: 2 / if I program imagine in the "playback 1", a sequence of various motions in chase version (40 cues for example), can I recall this playback in a master cue playback and if so how to proceed? To do this, you will need to trigger playback 1 from a cue in the Master Playback. To do this go into the Cue Settings in the cue in the master playback you wish playback 1 to be triggered by. Then press Macros..., and next to Trigger Cue Stacks click Add. Any programmed playback buttons on the console will then flash, which allows you to tap playback 1 to trigger it. Click OK on the macros window, and then the Cue Settings. When you go into this cue, as well as the cue running playback 1 will be triggered too. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
