SCE Posted July 28, 2019 Report Posted July 28, 2019 The gobo pictures as not complete on the screen. I use Stairville MHX200 scans. How can I solve this so I see the complete gobo sign on the screen, do I need to update the scan data? any suggestions? Thank you
Edward Z88 Posted July 28, 2019 Report Posted July 28, 2019 Hello, Please could you send a copy of your Fixture File to FixtureSupport@zero88.com, where one of the team will take a look to see what may be causing this. If you have any questions just let us know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
SCE Posted July 28, 2019 Author Report Posted July 28, 2019 Hi Edward, I use Fixture Library 37.00 that has been downloaded from your site. I have nothing changed in this file. just bought the solution desk last month. All works fine and I’m happy to work with the desk, one thing I miss is the correct manual for the latest soft version 7.9.5 the manual i got is not update and thats confusing.
Edward Z88 Posted July 28, 2019 Report Posted July 28, 2019 Hello, To confirm - are these fixtures Stairville MH X200 Pro Spots? I can't find MHX200 scans in the library. I have been able to recreate this issue with the Pro Spots in both modes. Taking a look at our library file, the images are correctly formatted. I will continue to investigate this and get back to you. The latest manual for Solution is currently ZerOS 7.9.2, available here... https://zero88.com/manuals/IM9210 - Solution Manual Issue 2.0.pdf For changes since this software version, see the software release notes, available with the software downloads here... https://zero88.com/forum/files/category/4-legacy/ ZerOS 7.9.5 is the latest software for Solution, available with release notes here... Just so you're aware, the latest Zero 88 Fixture Library is version 38, available from our website here... Hope this helps, if you have any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Edward Z88 Posted July 29, 2019 Report Posted July 29, 2019 Hello, Please find an updated fixture file attached for the Stairville MH X200 Pro Spots... MHX200ProSpot.ift Copy this file to USB, plug into the console, tap SETUP -> Load, and choose the fixture file to load in. You can then go to the Fixture Schedule, select your existing Stairville MH X200 Pro Spots, tap Change Profiles, and replace the fixture for the new personality labelled "EDIT". You can then click OK, exit Setup, click Auto Create Beam palettes, and you should find the gobo images load in correctly. Hope this helps, if you have any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
