RaffaABC Posted October 8, 2019 Report Posted October 8, 2019 Can someone help me to create a fixture for this type of lights .. PLEASE!!! https://www.amazon.com/Ridgeyard-Touch-Screen-Moving-DMX512/dp/B071KNQTL6/ref=sr_1_47?keywords=led+head+moving+light&qid=1565618648&s=gateway&sr=8-47 This are the specifications Specifications:Rated power: 300wVoltage: AC110v, 60HZColor: 14 colors + whiteStrobe: 0-12 times / secondReverse: horizontal / verticalDmx 512 channel: 16ch / 20chDimmer: 0-100% linear adjustmentLamp: 230w beam lights with bulbFantasy: eight prism effect controlFocus: independent electronic linear focusCooling system: built-in convection heat / airDescription trimming (x / y-axis precision): 8 / 16bitLevel of 540°, vertical 270°, horizontal / vertical speed adjustableEffect:pattern water effects / pattern jitter effect / linear rainbow effectControl mode: dmx512 / master-slave / auto / sync / voice / lcd displayFixed gobo wheel: 17 gobo patterns, made from high temperature special materialsPackage size: 42x 47x 58cm (16.5" x 18.5"x 22.8") /pcWeight: 22kg ( 48.5 lb ) / pc Quote
martin-144 Posted October 8, 2019 Report Posted October 8, 2019 Hi RaffaABC, The Zero88 guys won't be able to help you with this description. They will need to have a description of how the DMX channels are located. And if you can find out the channel allocation, you should mail it to FixtureSupport@zero88.com. And maybe here, just for interest. Martin Quote
Edward Z88 Posted October 8, 2019 Report Posted October 8, 2019 Hi RaffaABC, As Martin says, please send us a link/copy of the fixture’s manual containing the DMX channel map to FixtureSupport@zero88.com, and one of the team will be able to help you out and create the file for you. All the best, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
RaffaABC Posted October 11, 2019 Author Report Posted October 11, 2019 On 10/8/2019 at 2:47 PM, Edward- Z88 said: Hi RaffaABC, As Martin says, please send us a link/copy of the fixture’s manual containing the DMX channel map to FixtureSupport@zero88.com, and one of the team will be able to help you out and create the file for you. All the best, Edward Thank you Edward Here is the Tech Specifications that are on the Manual. Product name: 7R beam 230W beam moving head Power supply: AC90-240V, 50/60HZ LIGHT SOURCE: Ipcs 230W Light bulb FUSE: 7A DMX CHANNELS: 16CH COLOR: 14COLORS-WHITE PATTERN PLATE: 14PATTERN +WHITE MODELS STROBE: 0-10TOMES/SEC,ADJUSTABLE SPEED X-AXIS: 540'' Y-AXIS: 270'' LCD: ON/OFF PRISM: 8-FACET PRISM (16-FACET PRISM FOR CHOICE) FOCUS: ELECTRONIC LINEAR FOCUS FOST: WITH FOST EFFECT OPERATING MODE: DMX512, SOUND ACTIVED, AUTO, MASTER/SLAVE BEAM ANGLE: 3, 8'' N. W: 17.5 G, W: 18, 96 Quote
Edward Z88 Posted October 11, 2019 Report Posted October 11, 2019 Hi Raffa, We will not be able to make a fixture file from this information. We need the DMX traits and channel map, that state what each of the 16 DMX control channels does. If you do find this please email fixturesupport@zero88.com, and we'll be able to make the file for you. I believe Keith replied to your original email with an existing fixture file that he guessed may give you control over the fixture - I'm assuming this didn't work? If you can't find the information, you can patch 16 dimmer channels, and work through each one making a note of how it controls the fixture. This method is always difficult with fixtures with shutter parameters as well as dimmers and colour mixing, as many channels have to be at certain levels to get light output. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
RaffaABC Posted October 14, 2019 Author Report Posted October 14, 2019 Yes, that's rigtht Keith replied to me. But it didn't work And the manual that it came with the product doesn show any more information about the lights. Don't know what 2 do now..!! But thanks alot Quote
RaffaABC Posted October 14, 2019 Author Report Posted October 14, 2019 Just found the manual. Please tell me it works!! https://www.dj-store.ru/data/files/files/280_file.pdf Quote
Edward Z88 Posted October 14, 2019 Report Posted October 14, 2019 Hi Raffa, 1 hour ago, RaffaABC said: Just found the manual. Please tell me it works!! Please send a copy of the fixture's manual to fixturesupport@zero88.com, and we'll be able to make the fixture file for you. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
RaffaABC Posted October 14, 2019 Author Report Posted October 14, 2019 11 minutes ago, Edward- Z88 said: Hi Raffa, Please send a copy of the fixture's manual to fixturesupport@zero88.com, and we'll be able to make the fixture file for you. Edward Already sent Hope they can help!! Cheers Quote
kisi Posted 12 hours ago Report Posted 12 hours ago Need help to build a fixture file for my new light. Name of the light is Maverix - BSW 350 Can someone help me, I use a Vari lite FLX S24 console attached is the dmx chart. Best regards Kim Simensen Maverix-BSW 350.pdf Quote
Charlie Newman Posted 10 hours ago Report Posted 10 hours ago 2 hours ago, kisi said: Need help to build a fixture file for my new light. Name of the light is Maverix - BSW 350 Can someone help me, I use a Vari lite FLX S24 console Hi @kisi, welcome to the forum! I should be able to do this this evening for you, however you're also able to do this within the desk itself under "SETUP" -> "Add New Fixtures" -> "Create New Fixtures" Please let me know if you have any questions. Best, Charlie Quote
kisi Posted 1 hour ago Report Posted 1 hour ago @Charlie Newman I know. We tried and the "fine tilt" and some other stuff its missing there. Quote
kisi Posted 1 hour ago Report Posted 1 hour ago @Charlie Newman Can you please send the fixture to my email kim@eventon.no Thanks best regards Kim Simensen Quote
Charlie Newman Posted 1 hour ago Report Posted 1 hour ago No worries, give me a few minutes. Best, Charlie Quote
