Shanebyrne96 Posted November 21, 2019 Report Posted November 21, 2019 I can’t find the move in dark delay time in the new up date I need to speed it up ? Urgent enough anyone know where it is moved to ?
Shanebyrne96 Posted November 21, 2019 Author Report Posted November 21, 2019 Yep that would be general delay times I’m specifically looking for the move in dark delay time
kgallen Posted November 21, 2019 Report Posted November 21, 2019 Setup + Playback button should be the "global" setting. Above I was referring to the Settings specifically in the cue where I believe you can override the MOD time for that cue. However I'm more used to FLX (rather than FLX S) so sorry if the config is not in exactly the same place or the buttons are different. The 7.9.6 manual is here, see p44: https://zero88.com/storage/downloads/7f906b85-80f1-4646-bd18-d2327d94fc60/FLX-Range-&-ZerOS-Accessories-User-Manual-v7.9.6.pdf
