Setup + Playback button should be the "global" setting.
Above I was referring to the Settings specifically in the cue where I believe you can override the MOD time for that cue.
However I'm more used to FLX (rather than FLX S) so sorry if the config is not in exactly the same place or the buttons are different.
The 7.9.6 manual is here, see p44: https://zero88.com/storage/downloads/7f906b85-80f1-4646-bd18-d2327d94fc60/FLX-Range-&-ZerOS-Accessories-User-Manual-v7.9.6.pdf
