daniloT Posted November 27, 2019 Report Posted November 27, 2019 Hi I have a problem on FLX48, I do not know if it comes from the patch or spots. after having patched 3 spots showtec performer RGBAL 2000, I light them one by one; and when I turn on the 2 the 1 is strobe, when I turn on the 3 the 1 and the 2 are put there. Can someone help me please? Quote
Edward Z88 Posted November 27, 2019 Report Posted November 27, 2019 Hello, Can you confirm the mode and the patch on the fixtures match the settings on the console? Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
daniloT Posted November 28, 2019 Author Report Posted November 28, 2019 Mode Channel All in inverse 1 Spot 1 adress 1 et fader 1 Spot 2 adress 9 et fader 2 Spot 3 adress 17 et fader 3 Thanks Quote
Edward Z88 Posted November 29, 2019 Report Posted November 29, 2019 Hello, Can you confirm they are set to the 8 channel HSIC mode? If you are patching your fixtures manually, I would recommend disabling RigSync. To do this tap SETUP -> Universes -> RDM -> RigSync -> Disabled. If you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
daniloT Posted November 29, 2019 Author Report Posted November 29, 2019 Hi I confirm i put 8 channel. I disabled rigsync before i patch. There do again. Thanks for begin answer Quote
Erics Posted November 29, 2019 Report Posted November 29, 2019 Check the DMX Output Window, witch values are send to the spots. Try to switch the dmx adresses of spot one and spot two and see if the error switch with your adress change. if the same spot is strobing, its a lamp / mode problem. If the error is than one spot one, it could be a patch or flx problem. So you can see if it's the lamp , the desk, or the patching in the flx. Quote I use: Zero 88 FLX S48 / Chamsys MQ70 / Madrix / mostly Astera Lights
