is it possible on FLX S24 or S42 to name playback channels individually ?
if there is a possibility to do that i would be happy if you let me know
Jakob
Hi Jakob,
Yes, both playbacks and channels can be named, and their names can then been viewed in the faders window.
To name playbacks, press and hold SETUP and tap the playback's button to open the Playback Settings. Then tap Advanced, and tap playback name to give it a name. You can either use the onscreen keyboard or an external USB keyboard. A shortcut to access the playback settings, is to view the faders window on the touchscreen, and then press the on-screen fader.
To name a channel, press SETUP, and then tap the channel button you wish to name. You can then tap Change Names to give it a name. You can select multiple channels at once if you wish, and change all of their names at the same time.
Hope this helps,
30 minutes ago, Edward- Z88 said:
Hi Jakob,
Hope this helps,
Thanks this makes it way easier to find all my playbacks
