Question about Effect on FLX'S (recording possibility)
van den abbeele Eric
Hello
I m coming here  for a French user.
He had a FLX S 48 (I don't know which ZerOS version he use...)
And he's disappointed about effect generator, and explain that he can't edit effect...
So I was looking into the 7.9.6 manual, and not sure to find a good answers.
On page 37 (Waveform) at the end there is :
"Manually created effects can be recorded as a new palette in the same way as other attributes  manually create the effect, press the "RECORD" button which will display the Effect Palettes on the display, and select an empty palette.
Rotation cannot be performed on a per parameter basis and can only be applied to the Pan and Tilt parameters together. Therefore, the Rotation parameter can be adjusted via the control wheel, but is not displayed in the Effects Window."
So I I understand that Waveform aren't available on FLX S 48, is it possible to acmes to Speed, Size, Offset, edit all this setup and Record it on palette...
Thank for your help for this French user !
Eric VDA
Hi Eric,
That is correct. On page 37 of the manual in the Waveforms section, there are crosses (x) next to FLX S24 and FLX S48. This is because Waveforms are not available on FLX S. Waveforms are available on FLX only, as this window is much easier to navigate with the cursor keys.
Speed, Size and Offset (and Rotation for movement effects) are available on the encoder wheels to edit the auto effects on FLX S, in the same way they are on FLX.
Thank Edward.
Can you confirm that after editing effect (Speed, Size, and Offset) It's possible to recording editing on FLX S 24 and 48.
On page 37, waveform and recording section are on same page. And this page is writing like you explain with Cross for S24 and S 48.
And if it 's possible to recording effet after editing, perhaps it will good to confirm this with FLX Ok FLX S 48 Ok and  FLX S 24 OK
Something like this...
1480472990_Capturedcran2020-06-1719_02_54.thumb.jpg.fd97b5fc28881ef307fd47468fc6c3a5.jpg
Edited by van den abbeele Eric
That is correct. After adjusting the auto effects using the encoders, you can then tap RECORD, and then tap an empty effect palette to store the edits.
Hope this helps,
Ok thank
i will give this information to the French user That have problems about recording !
and this will give a right information in French forum !
thank Edward !
ps I will do a change on french Manuel to giving a complet information !
  • van den abbeele Eric changed the title to Question about Effect on FLX'S (recording possibility)
Good to help people ...
Take care Edward
