MihiGyver Posted January 31, 2021 Report Posted January 31, 2021 Hello We have an Leap Frog 48 and i made the update to 7.9.9 but that was so bad to work with. so i decidet to downgread it again to 7.9.8, and somehow all the effect of the moving heads works when i select them in the mfk but when i store them as an submaster or cue it is not working. the moving heads are going to the position the should start from but they are not moving. i tryd that with old programms and also new ones. someone any idea?
Edward Z88 Posted January 31, 2021 Report Posted January 31, 2021 Hello, 11 minutes ago, MihiGyver said: We have an Leap Frog 48 and i made the update to 7.9.9 but that was so bad to work with. What issues did you experience with ZerOS 7.9.9? ZerOS 7.9.9 contains some small enhancements and an updated fixture library. 12 minutes ago, MihiGyver said: i decidet to downgread it again to 7.9.8, and somehow all the effect of the moving heads works when i select them in the mfk but when i store them as an submaster or cue it is not working. If you tap Automatically Create Effect palettes in the Effect window, how many auto effects are created? You should see 45 auto effect palettes. In ZerOS 7.9.8, there was an issue with some fixtures not storing intensity effects correctly into cues. This is fixed in ZerOS 7.9.9. If you have any questions let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
MihiGyver Posted January 31, 2021 Author Report Posted January 31, 2021 I use the desk for live shows and more or less spontanous i have stored a movement in a cue and when i pressed the button it changed the speed. in 7.9.9 they moved but not right. but i go manly back to 7.9.8 because 7.9.9 was terrible slow. and it also lagt really hard and made errors, do you think that will get an other patch? there 45 effects. i think i will try 7.9.9 again..
Edward Z88 Posted February 1, 2021 Report Posted February 1, 2021 Hello, If you are able to email me a copy of the show file that is causing issues, along with the cue numbers that don't seem to be working correctly, I will take a look. If you have any questions let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
MihiGyver Posted February 7, 2021 Author Report Posted February 7, 2021 Hey i have send you the show file an i tryd some stuff. i open up the show file one phantom OS and there it works all fine the numbers on the DMX Output are rising and falling but on the desk its just not working.. and to be sure i also changed the CF card and reinstalld the operating system and it is still not working. and i also reseted the desk and mad a new show and its also not working. i tryd that all with 7.9.9 next weekend when im at the console i will try that with 7.9.8 i have seen that my console has just 256Mb of ram would it make an performance boost if i replace the Ram with a GB or something like?
Edward Z88 Posted February 8, 2021 Report Posted February 8, 2021 Hello, Thanks very much for emailing me your show file. I will reply to your email. If you have any questions let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
