delfine Posted July 5, 2021 Report Posted July 5, 2021 Bonjour, je mets dans un playback plusieurs effets concernant les mêmes projecteurs. un effet par cue. J’aimerais que le fader règle l’intensité de l’effet en cours, ça fonctionne, mais si j’ai le malheur de l’éteindre et que suis par exemple sur la cue 2, elle revient en cue 1, or je voudrais qu’elle reste en cue deux ? Quelle étape ai-je oublié ?? merci delfine
Edward Z88 Posted July 5, 2021 Report Posted July 5, 2021 Hello, To achieve this, you can disable Release On Lower. To do this you can hold SETUP, and tap the button of your playback. Then choose "Raise and Lower" from the top, and disable Release on Lower. For more information, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower Hope this helps, Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
delfine Posted July 5, 2021 Author Report Posted July 5, 2021 1 hour ago, Edward- Z88 said: Hello, To achieve this, you can disable Release On Lower. To do this you can hold SETUP, and tap the button of your playback. Then choose "Raise and Lower" from the top, and disable Release on Lower. For more information, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower Hope this helps, Edward Thanks a lot. I will try !
