Hi Jouper,
57 minutes ago, Jouper said:
When i try to downgrade my zero solution i only get a boot error when downgrading to version 7.8.2.39
After installing the software, do you have any USB storage devices plugged in whilst booting the console? If so this will cause a boot error. To perform a fresh install of the software, please see the software update instructions below...
https://zero88.com/manuals/zeros/software-updates/zeros-usb-creator
If you have any questions please let me know.
It creates the boot error before bringing me to the install screen so i only put in my usb stick with version 7.8.2.39 and start the console and the first thing i see is boot error
Hi Jouper,
I'd recommend formatting the USB stick you are using in Windows, and then run the ZerOS OS Creator software again to create the bootable drive. If you are still having difficulty, please see the link below...
https://zero88.com/manuals/zeros/software-updates/zeros-usb-creator/mbr-2
