Holger Posted April 25, 2022 Report Share Posted April 25, 2022 After updating from 7.9.4 to 7.11 the DMX 3 pin output does not work anymore. (Before, it did.) Can this be a software problem? Are there any new settings to control output via DMX 3 or 5 pin? @Edward Z88 I tried all the stuff in real (with connected lights) on the weekend and I got this problem that the 3 pin DMX does not work anymore.... Quote Link to comment Share on other sites More sharing options...
KWR88 Posted April 25, 2022 Report Share Posted April 25, 2022 The settings for the output have not changed but it is possible if you have load a show file from 7.9.4 that has only one universe patched it has only enabled output 1. If you go into setup universe, check universe 1 has both Output 1 and 2 selected not just output 1. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Holger Posted April 25, 2022 Author Report Share Posted April 25, 2022 Thanks! Could be the problem. May you suggest what I should do with the name? (See attachments) DeskUniverseOutput_a.jpg - Settings DeskUniverseOutput_b.jpg - After Add DeskUniverseOutput_c.jpg - After click on Output DeskUniverseOutput_d.jpg - After entering 2 as in your screenshot I will test is today in the evening. Quote Link to comment Share on other sites More sharing options...
KWR88 Posted April 25, 2022 Report Share Posted April 25, 2022 As you have done enter the number2 and on the next screen select the "use on this desk universe instead" option. That should then give you the name Output 2 as per my original image. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Holger Posted April 26, 2022 Author Report Share Posted April 26, 2022 After renaming new Output to Output 2 it worked! Thanks! 1 Quote Link to comment Share on other sites More sharing options...
