DMX output 3 pin nor working after software update to 7.11
Holger
After updating from 7.9.4 to 7.11 the DMX 3 pin output does not work anymore. (Before, it did.)
Can this be a software problem? Are there any new settings to control output via DMX 3 or 5 pin?
@Edward Z88 I tried all the stuff in real (with connected lights) on the weekend and I got this problem that the 3 pin DMX does not work anymore....
The settings for the output have not  changed but it is possible if you have load a show file from 7.9.4 that has only one universe patched it has only enabled output 1.
If you go into setup universe, check universe 1 has both Output 1 and 2 selected not just output 1.
Regards,
Keith Rogers
Thanks!
Could be the problem. May you suggest what I should do with the name? (See attachments)
DeskUniverseOutput_a.jpg - Settings
DeskUniverseOutput_b.jpg - After Add
DeskUniverseOutput_c.jpg - After click on Output
DeskUniverseOutput_d.jpg - After entering 2 as in your screenshot
I will test is today in the evening.
