  1. Yesterday
  2. Just putting what I posted on the Zero 88 Users Group here in case anybody needs a solution to the same problem.
  3. Last week
  4. Hi Peter, I've just replied to your post on the Zero 88 Users Facebook Group. Give it a go and let me know how you get on. Archie
  5. Is anyone experiencing the same problem I’m having. I’m operating on software version 8 build. Operating 3 Chauvet Rouge 2 wash moving heads. When I fade out pressing the go button on the main stack the Moving heads, instead of just fading out and staying in the position they were programmed in they move to the home position with the colour going back to white. Because of that the Move on Dark doesn’t work so when I press the go Button again the lights in full view move to the new position. Exasperating. Anyone any ideas to correct this. I didn’t have this problem with any other software version Peter Allman
  6. Earlier
  7. Fantastic to hear it is working. Please feel free to ask any more questions if you have any. Archie
  8. You're a star. Took me a minute to get the ports talking, but it is working beautifully.
  9. The Vari-Lite service department has been very helpful. Thank you Ryan and Kgallen.
  10. I don't have a Jester or any service information sorry, but you might want to check out my post below to see if you have a similar issue. Actually... looking through my emails, seems we've already conversed on this on the Blue Room. Sorry for the repeated info, I guess that's not the issue then? Also on a PM on BR I gave you some instructions for contacting the current support. Did you use those?
  11. I don't have a Jester or any service information sorry, but you might want to check out my post below to see if you have a similar issue. I will also send you a PM.
  12. Hi I have a Zero-88 Jester ML24 lighting controller. It gets used for local charity and non-profit shows. I suspect there is an internal fault with how the faders are multiplexed. The most obvious fault is that the Grand Master fader will only go to 75%, but operating other faders will make it go to 100% as they get to full travel. In test mode, the flash buttons work correctly, but the associated fader will not be 'read' correctly, however another nearby fader will operate in place of the desired one. There is a new battery installed, the desk has been reset and the last available firmware and fixture library installed. I've made up and tried a new ribbon cable assembly in case the original was faulty. Is it possible to get internal schematic diagrams for this desk so I can get busy with a 'scope and meter? Thank you.
  13. Hi @CestM0i64, In ZerOS, Playback 0 is the master playback, so using OSC (e.g. /zeros/cue/go/0/20) will go to cue 20 in the Master Playback. Therefore, Playback 1 will be go/1/<cue number>, and so on. Hope this helps, feel free to ask any more questions you may have. Archie
  14. As per this article I'd like to trigger a cue using OSC. https://www.zero88.com/manuals/zeros/setup/triggers/osc-examples Is the master fader addressed as 1 and then subsequent faders are incremented e.g. Master = 1, playback 1 = 2 or does it have a separate address e.g. 0, M? I'm not currently at the desk so trying to get ahead of the game before I go to programme a show in a couple days where I'd like to trigger some cues from QLAB when they coincide with SFX & VFX cues.
  15. Thank you so much!
  16. Your fault is probably in “cue 2” where there are blocking values that stop the mover prepping for “cue 3” but in your real cue list where you’ve been copying what I said in previous posts is most likely the case. I’m assuming here you haven’t deliberately set ‘Don’t Move’ in any related cue Cue Settings - if you have that’s self explanatory!
  17. See https://www.zero88.com/manuals/zeros/cues-playbacks/playback-settings/advanced?filter=2 for whole playback unblock.
  18. Copying cues results in blocking cues when you paste. You will see white intensity numbers in the output screen. 1. Save your show. 2. GO into a cue you copied to, which shows the white intensity numbers. 3. Press and hold UPDATE to bring up the options window. Ensure SmartTag is enabled (red stripe). Press enter (or tap the playback go button) Blocked values should change from white to purple (tracked) (unless you subsequently changed them after pasting in which case they will be blue or green) and now your move on dark into that cue should work. 4. Repeat for other copy-pasted cues. Note: There is a method to unblock a whole playback in one go but I can’t remember where that option is. Check the manual. 4. Check the results on stage.
  19. Our show (opening in 2 days) is now lit, but in the process (including inserts and copying), for some cues the movers do not move on dark. ('Move on dark' is set on the board, a FLXs 48). I assume that in the editing process, somehow the move on dark or track forwards functions have been corrupted in one or more cues. Simplistically, if I had 3 cues: 1. mover (working) 2. dark 3. mover (moves to position when cue activated) In which cue is the fault likely to be? Do I need to delete the cue and re-enter, or is there another fix? Many thanks.
  20. Ever since acquiring my Frog 2, I noticed that with the Dockhouse (Capture) Demo Presentation show file for ZerOS (available from Zero 88 here), it is of course a .zos file. The change from .isf to .zos for show files was made in ZerOS 7.9.8, a version of which is after 7.8.2.39 (the last supported software version for Frog 2) meaning Frog 2 only loads show files saved with the .isf extension. This means my fellow Frog 2 users won't be able to use the Capture Demo File for learning or having a play/experiment, so I have "converted" the .zos show file to .isf in order to be compatible with Frog 2. I imagine the audience for this won't be too large anymore since I feel Frog 2 popularity has died down significantly, but I'm posting this as a public resource in case it is of use to anybody who still uses a Frog 2 or a console on a version of ZerOS before 7.9.8. When loading in the show file, you'll be told it was from a Frog 2 and that some data won't be loaded. There shouldn't be any reason that some data won't be loaded with the way I've done this, but if you are loading this file onto a Frog 2, UDF 1 (User Defined Fader) will have a stored state on it. If loading this onto a different console type without UDFs (e.g. Solution), this should be transferred onto playback/submaster 1 (theoretically). It is also worth noting that this .isf show file is only within the limitations of Frog 2 - meaning the other higher universes found on the .zos version won't be seen or usable (Universe 5 & 6). The attached show file loads with the newer ZerOS skin if on Frog 2 - other consoles have that skin by default regardless, to provide a familiar user interface appearance to the other consoles people may have used with capture in comparison to the light grey and green classic theme on Frog 2. I have tested the .isf file with the Zero 88 provided Dockhouse 2022 file designed for the .zos version and it does work correctly. Anyway.. here's the show file, hope it is of use. Z88 Capture Dockhouse v7-8-2-39.isf
      • 1
      • Thanks
  21. Hello Kisi When you start creating a fixture file with Fine or 16 bit resolution, select Pan then select 16-Bit on the bottom line, then when you select OK, CH1 will be Pan and CH2 will be Pan fine. Then when you select CH3 and select Tilt, the Fixture creator will put Tilt as Ch 3 and Tilt Fine as CH4
  22. No worries, give me a few minutes. Edit: Send to your email Best, Charlie
  23. @Charlie Newman Can you please send the fixture to my email kim@eventon.no Thanks best regards Kim Simensen
  24. @Charlie Newman I know. We tried and the "fine tilt" and some other stuff its missing there.
  25. Thank you for this information, it definitely sounds like ZerOS Watchdog kicked in while loading the show file. It would have displayed a list of registers and then also a stack trace. Archie
  26. It was a crash dump (like a Linux shell window?) on the monitor. but then the monitor froze and i rebooted.
