It’s easy, you’ll be fine! -
Hi, an update. Not too successful, but partially. We lay the console down, unscrewed the six access screws holding the front panel on, (i also put the earthing wriststrap on before doing this), and upon opening the console there was no obvious disconnection of the ribbon cable but we pushed down the clips to make sure it was secure. One was solid, the other flexed a bit on pushing. We then closed the console up, securing one screw top and bottom in the middle of the set of screwholes and turned it on. All worked perfectly. So we turned it back over, put the four remaining corner screws in, turned it over, plugged it back in, the fault was back. Do you think I need to replace the clip that had some flex in it? Do you think that is the issue with the intermittent fault on the LCD displays? - Earlier
kgallen started following JesterML LCDs blank [still backlit] and MFK lcd top row malformed
I'll let you know soon 😉
