Hi @Alexandre, apologies for the late reply but I thought it was worth sharing this. Thank you for providing your show file. You're correct, the crash behaviour is related to Move on Dark being used in Playback 7. Upon further investigation of your show file, cue 3 in Playback 7 contains the 'Smooth' effect (E5 to be precise) applied to fixtures 2-9 and 49-54. After messing around with Move on Dark and only enabling specific attributes (position, effect, etc.), it appears that Move on Dark is looking forward in the cue stack (from cue 1 & 2) and is attempting to apply an intensity effect (Smooth) to fixtures that are at an intensity of 0 in that cue (essentially - those fixtures have no intensity values to modify by the effect / have had no intensity instructions as their intensities are not set in that cue and the previous ones - tracking is enabled). Note that 'Smooth' is an intensity based effect, which is likely the reason for the crash behaviour from what I can see. Instead of disabling Move on Dark generally for the whole playback, in ZerOS we have the option to disable certain parts of it, ensuring you don't lose out on any advantages of using Move on Dark e.g. with colour and position in sacrifice of effects to prevent crashing. To do this, you'll need to turn off the effect attribute for Move on Dark for the specific cue(s) that are causing you problems with Move on Dark so the console ignores any effects that may cause issues for that cue specifically. You could alternatively go the simple route - disabling effects in Move on Dark for the whole playback instead of just individual cues, but that will result in (for example) position based effects not being taken into account by Move on Dark, meaning effects such as 'Circle' won't be applied in dark - you will see them apply from 0 effect size to their defined effect size for that cue over the defined fade time as the fixture's intensity is brought up. You can, however, resolve this*. Disabling Move on Dark for effects only on specific cues: In the 'Settings' column in the cue stack, tap 'Add' on the cue you wish to disable effects with Move on Dark Tap 'Don't Move Effect' so it has a red indicator as opposed to a blue one (red is 'activated/selected', blue is not) Tap 'OK' Effects with Move on Dark has now been disabled for just that cue. When launching into this cue, effects will now be applied on the press of GO into that cue. You can do this for every cue that is causing a problem. Disabling Move on Dark for effects only on the entire playback: Hold the 'Setup' key on your console's front panel and tap your playback's flash button On the internal touchscreen (or monitor if using a FLX S48), tap 'Move on Dark' Tap 'Don't Move Effect' so it has a red indicator as opposed to a blue one *By enabling 'Don't Move Effect' for the whole playback in the playback's settings, inside each specific cue's settings referred in my first set of bulletpoints, that option will now have changed to 'Move Effect' (only for cues within that playback). This allows you to tell the console to look ahead in the cue stack and move the effect-based things for a specific cue anyway, ignoring the playback's general settings for Move on Dark that all effect movements are disabled. An example of this is shown in the image below in the far left column of options: I hope this helps, and I hope your FLX S continues to serve you well. Kind regards Archie
Old post I know but your only hope now is one of the distributors: https://www.zero88.com/distributors/list/united-kingdom-and-ireland 5 are listed in the north west, but I don’t know which if any are still Zero88 dealers, or can offer repair services. Keith and Ian Knight are both gone (in different ways unfortunately). -
The manual page 51 says the DMX input port performs a merge into the DMX output. See also page 20 item 4. So if you patch to different addresses it seems like this should work after cabling the DMX output of one Jester into the DMX input of the other. So have a read of the manual, and more importantly, try it out. https://www.vari-lite.com/b-dam/vari-lite/discontinued-products/jester/english/jester-manual-3-4.pdf Note: All our friends from Zero88 are gone and no one from Vari-lite has any interest in their current consoles let alone legacy ones they had no involvement with. So unfortunately we’re ’flying solo’ now. So us users (or non-users in my case with Jester) is all there is now. If you find out that you can (or indeed if you can’t) chain Jesters like this to expand your controllable channel count, it would be good if you’d take the time to document your findings here, to help other users. Good luck with your show. -
Davidmk started following Blind edit without impact from life scene
- 1 reply
- 1
I mean.. not to lead too far away from the post's original topic with my message below, but if we're on the topic of analysing ZerOS... relatively recently I loaded ZerOS up and had a play around. I'm not sure if it has been discussed before, but I discovered that ZerOS used to have (or still has - I just cannot seem to find it) a partial theme editor for the external monitor's UI appearance.. in newer versions it seems to have disappeared though. This was on ZerOS version 7.8.2.39, so that software version was released just nearing the end of 2016 and was the last available one for Frog 2. I also found a "Testbed" window, which was most definitely for development purposes of displaying cells, buttons, tickboxes, dropdowns, and other UI elements that need to be presented by the software. Below, I've attached three screenshots that I took today to show here. The first two relate to the "Display Palette Editor" (theme editor, one screenshot is the default view and the other is when I'd edited some colours such as the background to be green and button text to be pink) and "Testbed" for UI elements. P.S. admins - I apologise if sharing this isn't allowed for development reasons, please delete my post if that is the case Safety notice - if you somehow find this on your console (I won't say how I got these windows, to prevent any misuse of it or people potentially making mistakes) - I definitely don't recommend changing any values at all, because when resetting the desk, it won't reset these values.
