  1. Past hour
  2. Ah perfect, thank you ! Forgot you could trigger cue stacks.
  3. Today
  4. You create a chase on a fresh playback. Then you trigger and release that chase playback from cues in your main cue stack. To be able to get at states in your chase you use SHIFT-Playback GO to get to the state you want to edit without the chase running on. Then you edit the state using UPDATE as you would any other cue. https://www.zero88.com/manuals/zeros/cues-playbacks/chases
  5. Yesterday
  6. Hi all, if I remember correctly you can create chases within cue stacks. If you can do this, how can one edit those? Need to have a repeated set of states, and a chase is unfortunately the best option (unless I'm missing something), as you can't trigger cue stacks from other cue stacks. Thank you in advance!
  7. Last week
  8. Hi @Worcester RGSTech, Please find the fixture personality file attached. Regards SL-H7 _ SL-H12.ift
  9. Hello Hive Mind. In my other venue I have some qtx SL-H7 LED floods which I would like to to run from the Solution. They do not appear to exist in the fixture library within ZerOS 7.14.4 Does anyone know of an alternative fixture whose details I could use? Thank you
  10. Hello Vari-Lite Team, any updates on a bug-fix release for ZerOS 8? @DMH @RJP
  11. Earlier
  12. No worries, always fun and I guess I learn some things I didn't know were important
  13. Alright first of all, thanks. I meant impedance, for some reason I wrote resistance, oops. I talked with the one responsible for the tech we work with and he told me that its all 'High quality microphone cables' from Stagg. If I understood correctly, they just made a massive order and because we *mostly* work with sound as many of the lights are build-in, they never bothered to buy DMX ones. I guess because its always a hastle to buy things for a school (legal stuff, since its the states money). I suppose we haven't had any big problems, I guess maybe because our lights aren't crazy special ones.
  14. The other reason I use this is that I set moving heads to default positions/beam. They are different for every show and a latched button/sub is so easy to change compared to messing with defaults. Anyway, well done, so glad to hear it!
  15. I finally got a chance to try this yesterday and it worked! (A latched submaster with colours set to zero on affected fixtures.) Oddly, a few MFKs initially didn't work with it (either not coming up at all or affecting other lights they hadn't affected before) and I could find no difference at all between the ones that worked and the ones that didn't. But re-recording the ones that didn't work fixed them so I was happy.
  16. 😃 Seems like we are in a minority worrying about impedance (although relevant to op). A pragmatic view is that, if you have a tester that checks framing and has a flicker finder, a DMX source that passes those tests and a normal continuity/wiring tester, then any cable that passes continuity and doesn't introduce flicker or framing errors is a good cable until proved otherwise in practice.
  17. The AI overview on search term ‘what is a transmission line in digital signalling’ seems pretty good. It has characteristic impedance and signal termination sections. Sorry to the OP, we’ve probably gone a bit over board now! 🤓
  18. Actually in audio the shell shouldn’t be connected to pin 1 either. Pin 1 is signal ground, shell is chassis ground and they aren’t the same thing as they deal with different types of interference (electrical, magnetic). https://www.ranecommercial.com/legacy/note165.html
  19. Another point with XLR audio and DMX is the connection of the shield - it shouldn't be connected to the XLR shell, only the pin 1 in either. Doesn't help tell them apart but worth checking at the same time if measuring impedance.
  20. Yeah but Google "what is a transmission line in digital contexts", ignore the AI and go for Wikepedia although you'll need a coffee, some biscuits and a comfy chair. I think I may be learning more than the original author here!
  21. For analogue audio cables, the impedance is not really an issue because the signal frequencies involved are very low. For digital signals the edge rate is very important and the capacitance of the cable has a big effect on this. Even for DMX at 250kbit/s the required frequency components can be well into the megahertz. Analogue audio cables of any appreciable length as can be found in DMX runs will severely attenuate the high frequencies required to convey a digital signal properly. For a digital signal like DMX, the cable acts like a ‘transmission line’ (Google that). That’s why we use terminators.
  22. An ohmmeter won’t help you. The cables don’t have a different dc resistance they have a different ac impedance. The most practical way to tell is from markings on the sheath of the cable that will tell you it’s ’DMX’ or ‘digital’ cable maybe. If it says ‘microphone cable’ it’s not really for DMX use. You can use ‘DMX cable’ for microphones but ideally not ‘microphone cable’ for DMX. (My response coincided with David’s posting, I’ll read that now!).
  23. So now you are into something of a grey area - I fully expect this response to attract comment. It especially needs comment from a sound tech as I'm hazy about that side of things. You can often get away with audio cables for DMX but no-one in their right mind would recommend that because you might not get away with it and you can bet the problems would only be apparent mid show and not at fit-up. The easiest way to tell the difference is to see if it is printed on the cable . 150ohms is not the resistance of the cable it is the impedance. Cables do have a resistance but it is dependant on length and is only important if the cable is meant to carry a current (as in mains cables where it is very important and is part of PAT testing). As far as I can tell from researching it, DMX cables should have an impedance of 150ohm as you said). 110ohm is allowed but not recommended. I'm guessing, but I suspect anything below 110ohm is likely to cause problems. The standard for audio is 110ohm but there is a wide range in use - 60ohm to 150ohm is quoted. Apperently, the main thing for audio is that the source and cable should be low impedance and the sink should be high (e.g. 10,000ohms). I Googled "what is the correct impedance for balanced audio cables" and read the AI response to get this information. This would suggest that a "standard" impedance audio cable would be acceptable for DMX but the really low (below 110ohm) cables would not. You can measure the impedance of cables with the right equipment but you can't use the resistance range of a multimeter. Google "how to measure the impedance of a dmx cable" for ways to do it. Your physics lab techs might be of help in this area. Ultimately it is better to keep your audio and DMX cables apart and mark them with something obvious so you can put them away properly. (That's a big ask in a school I know.) There is a reason why the standard for DMX is 5pin XLRs even though it only needs 3pins and 3pin XLRs are cheaper.
  24. Hello again, so recently I found out that the existing cables in the school where I work with lighting and sound sometimes, has mixed xlr and dmx cables. The 'build in' lights in the auditorium are definitely dmx' as they've been done by a third party. But all other cables have been used for both sound and lighting. Now I know the difference between the cables is mostly their resistance, 120 ohm at dmx right? I read online that meters and measuring that level of resistance isn't as easy (and I don't think we got an ohmmeter). So is there a way to distinguish these two (is there a reason to?). And yea, all cables are 3pol. I kinda want there to be some order. Thanks Jan
  25. Edward has covered this in several posts on this forum including https://www.zero88.com/forum/topic/10062-ad-as-additional-adress-unpatch-missing/#comment-42186 , where RigSync had repatched a fixture so the "Add As Additional" button was not available. I have pasted these comments as they may be relevant : Setup > Fixture Schedule > tap on a fixture's DMX address to open "Edit DMX Address". If the "DMX Universe", "Unpatch", and "Add As Additional" buttons are hidden, this indicates that the selected fixture is an RDM device that has been discovered by RigSync. It is not possible to unpatch a fixture discovered by RigSync, or give it multiple start addresses. Sorry to hear that RigSync changed the settings of RDM fixtures when you didn't want it to. If you go to Setup > Universes > Remote Device Management, there is a "Revert Rig Back" button, which will tell the fixtures to go back to the settings they had when the console found them. You would need to re-patch the fixture manually, to be able to access the "Add As Additional" and "Unpatch" buttons. Obsidians gain is our loss unfortunately.
  26. Thanks DALX, that’s exactly what I needed, makes my life so much easier 😀🙏
  27. Hello Oliver_74 You can use the Add as additional address function found in the Edit DMX Address window to pair your five fixtures. When you select the DMX address of the first fixture you want to pair, the curser will flash in the DMX address window which will be blank. Type in the address of the second fixture in the pair, select Add as additional address, then Enter. The Fixture schedule window will show two addresses for the channel fader of the first fixture. I only found this last week when I wanted to pair dimmer channels under one fader.
  28. So,you had them on 5 channels. e.g. Say were your fixtures had addresses 10, 20, 30, 40, 50, 50, 40, 30, 20, 10 and you patched them to desk channels Ch 1 = DMX 10, Ch 2 = DMX 20 and so on to Ch 5 = 50 You then recorded cues and playbacks using these 5 channels. So they are now addressed as 10, 20, 30, 40, 50, 60, 70, 80, 90, 100 These will need to be reflected in the patch however there are two ways to do this You could patch them as Ch 1 = DMX 10, Ch 2 = DMX 20 and so on to Ch 5 = 50 then Ch 6 = 60, Ch 7 = 70 and so on up to Ch 10 = 100 If you do this then channels 1 to 5 will still appear in all the cues and playbacks but channels 6 to 10 will not and will have to be added to all relevant cues and playbacks. Alternatively, you should be able to patch two fixtures to each of the existing channels as Ch 1 = DMX 10 and DMX 100, Ch 2 = DMX 20 and DMX 90 and so on up to Ch5 = 50 and 60. This would mean the show would look exactly the same but you would still have to treat the fixtures as pairs. (I know you can do this on the full FLX but I can't find it in either the full FLX or the FLX S versions of the manual)
  29. Hi @Oliver_74, Just to be absolutely sure, do you mean importing an entire patch consisting of (for example) dimming channels, and LED fixtures, or do you mean you want to import a custom fixture profile into your patch, replacing a previous profile or adding a new one? If you mean that you wish to import an entire patch into an existing show file, this is unfortunately not possible within ZerOS. The patch must be edited within the show file. It may be of use making the patch, then saving as a separate file onto the root of a USB stick, however if you build new cues in one file, they will not carry over to the other, resulting in both (or more if multiple) eventually becoming out of sync with each other.
