- Past hour
Old post I know but your only hope now is one of the distributors: https://www.zero88.com/distributors/list/united-kingdom-and-ireland 5 are listed in the north west, but I don’t know which if any are still Zero88 dealers, or can offer repair services. Keith and Ian Knight are both gone (in different ways unfortunately). -
The manual page 51 says the DMX input port performs a merge into the DMX output. See also page 20 item 4. So if you patch to different addresses it seems like this should work after cabling the DMX output of one Jester into the DMX input of the other. So have a read of the manual, and more importantly, try it out. https://www.vari-lite.com/b-dam/vari-lite/discontinued-products/jester/english/jester-manual-3-4.pdf Note: All our friends from Zero88 are gone and no one from Vari-lite has any interest in their current consoles let alone legacy ones they had no involvement with. So unfortunately we’re ’flying solo’ now. So us users (or non-users in my case with Jester) is all there is now. If you find out that you can (or indeed if you can’t) chain Jesters like this to expand your controllable channel count, it would be good if you’d take the time to document your findings here, to help other users. Good luck with your show. - Last week
Davidmk started following Blind edit without impact from life scene
- 1 reply
- 1
Kauz started following Blind edit without impact from life scene
I mean.. not to lead too far away from the post's original topic with my message below, but if we're on the topic of analysing ZerOS... relatively recently I loaded ZerOS up and had a play around. I'm not sure if it has been discussed before, but I discovered that ZerOS used to have (or still has - I just cannot seem to find it) a partial theme editor for the external monitor's UI appearance.. in newer versions it seems to have disappeared though. This was on ZerOS version 7.8.2.39, so that software version was released just nearing the end of 2016 and was the last available one for Frog 2. I also found a "Testbed" window, which was most definitely for development purposes of displaying cells, buttons, tickboxes, dropdowns, and other UI elements that need to be presented by the software. Below, I've attached three screenshots that I took today to show here. The first two relate to the "Display Palette Editor" (theme editor, one screenshot is the default view and the other is when I'd edited some colours such as the background to be green and button text to be pink) and "Testbed" for UI elements. P.S. admins - I apologise if sharing this isn't allowed for development reasons, please delete my post if that is the case Safety notice - if you somehow find this on your console (I won't say how I got these windows, to prevent any misuse of it or people potentially making mistakes) - I definitely don't recommend changing any values at all, because when resetting the desk, it won't reset these values. -
@Archie D @MD1125 You are out of my experience here. Nearest I've been was programming PDP11s 50yrs ago. No desire to return to that level of detail -
@MD1125, thank you very much for sharing and outlining this. Analysing network traffic.. I wouldn't have figured that out straight off! That's really interesting to see how ZerOS handles inputs from the mobile apps. I recognise the Z88R part of the string - presumably meaning "Zero 88 Remote". When I opened some of the obfuscated files that ZerOS contains (built on a linux system), most begin with "Z88C" from what I remember, presumably meaning "Zero 88 Console", so I can see the links starting to form...
