  1. Past hour
  2. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  3. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now jf
  4. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  5. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  6. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  7. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  8. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now hc
  9. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  10. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now yhd
  11. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now fugj
  12. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call NowFunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now cxfj
  13. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now fh
  14. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now bfhf
  15. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  16. FunRupee Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-789-4720-560_Call Now
  17. Yesterday
  18. Hi there, we have a problem with the default attributes of our LED Fixtures. Till version 7.___ it was without problems possible to record the defaults atttributes for each fixture with "record" "home" "defaults". Now with version 8 thsi works as well but it happens the following: after each restart even if the values of all attributes are recorded correctly and double checked before switching of the concole, the default attributes are erased and it happens there are random attributes recorded e.g. white 82, red 0, green 18 and blue 2. Can anybody help? One more thought: Perhaps it's only coincidence and has nothing to do with the new version of the ZeroOS and the internal memory of our Console is damaged!? Best, Bernhard
  19. Last week
  20. This video on multicell for FLX S might help, or as revision:
  21. I have some pixel batten fixtures. When I run a chase effect across a fixture it chases across those pixels. When I run the effect across multiple fixtures, it will chase across them all in order. I’d like for all the battens to pixel chase at the same time as a group. I thought it could be something to do with the offset of the effect, however when I select ‘offset as group’ it ignores the pixels and treats each batten as a single light source. I’ve attached a video of how it works currently and an edited video of how I want it to be able to work. How it works now: https://youtu.be/gVSUg7lTL2w How I want it to work: https://youtu.be/qIHcmw-siQs Is there something I’m missing? Thanks!
  22. Davidmk
    ninian
  23. Nin
    ninian
  24. @dtyotam See this post for links to the (Google) Apps:
  25. Hi @dtyotam I'm pretty sure that the Google Play Store deleted/closed the account that the remote apps were under, after they transferred over to Vari-Lite and Zero 88 was no longer under Cooper. This therefore rendered the apps un-downloadable. I'm not sure if there is another possible solution to download them, maybe an APK file? I just thought I should share this information.
  26. Earlier
  27. Ooh, this looks very promising. If it works (on our board) this might be just what I'm looking for. I'll let you know. All your help is very much appreciated, in any case, many thanks.
  28. @Phil Mckerracher @kgallen So, after testing this on both v7.14 and v8 I have shown that... You don't seem to be able to alter defaults on a Solution showfile - even when it is loaded on an FLX running the FLX-only v8 and been saved on that and reloaded. This seems so wrong that I fear it may be me and the way I am doing it. If it isn't then it probably warrants a call to support. You can achieve default colour black by making amended copies of fixture personalities. Fixtures with a default of white behave exactly as I would expect (i.e. the reverse of what you and I would like). They start with white and, as the playback is raised, they fade out the colours that are not needed. Fixtures with a default of black, on the other hand do what I expected and would like and also what I suspect you need. These start at black and fade up the colours needed. Where another playback is already up the (default white) fixtures, the behaviour of the both black- and white-default fixtures is to raise the "missing" colours and the lower the "unwanted" ones effectively replacing the original PB's colour with the new one. T would seem to be the required behaviour but contrasts with faders set up for colour mixing. If you want to mix playbacks then you should refer to the instructions for this in the manual. My recommendation for you achieve the look you require is to set a default of black fr LEDs in your showfile. While this does not seem to be possible through changing the fixture defaults you can do it by creating modified fixture personality files and replacing the library ones in the patch. However there is another way - one which use all the time. On an FLX I use a multi-function key (latched and with release disabled). I save all the default values I need for a show onto this. Not just default colour black but things like stair edge lights at 50% and default positions for moving heads. I engage this when I start the desk up and record the "default" values I need for that day's show on to it. These values would, of course, be restored whenever that show file is loaded. As you do not have MFKs you could use instead. You might find it helpful to disable raise-on-lower on this PB. Be careful about recording HTP levels on this as they will become the minimum level for those fixtures and you will not be able to go below it. For our stair lights this is, of course, exactly the behaviour I require. Hopefully, this, and the various bits I have sent you by DM wi help you to achieve the reults you require. Have fn!
