  1. Past hour
  2. Yesterday
  3. Simplest solution is to have all of the fixtures as one dmx address. Assuming that isn't an option or not ideal, it does seem to be a tricky one that I don't believe the video kgallen has pointed to actually addresses. It covers doing what you're already able to do - I watched it not that long ago as I was interested to do what you want to do and ended up just putting them on one dmx address for speed, but have been meaning to experiment since. I suspect you may be able to save the parameters of the effect to a palette, then apply it to individual fixtures in turn, until all of them are doing the same. I'm not convinced it won't just start rolling into doing what you already have though as soon as you add each fixture. Last option is manually creating your own playbacks with as many cues as required to make the effect. As far as I can see though, when you select pixels across multiple lights, the desk just treats them as a big line of lights and doesn't seem to have any understanding of grouping them into fixtures.
  4. Thanks Kgallen, I reproduced it in the channels mode I needed in no time with Fixture Editor 😉
  5. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. hope fund Loan App Customer” Care Helpline Number🇮🇳 (+91.∆.)- 797O-355140 @! (–𝟕𝟗𝟕∞𝟎𝟑𝟓→𝟓𝟏𝟒𝟎/y–)!-!call now. To d
  6. Hmmm not sure I know of a way. Want to upload the zfix here so we can have a play?
  7. is it possible to transform a .zfix fixture file from my s48 into an .ift file to be read by my beloved Frog2 without rebuilding it with the Fixure Editor. Thank you P.
  8. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji ek a very good
  9. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji ej sjs sjs anakns
  10. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji shub prabhat dosto ko
  11. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji smjh hii sir sir
  12. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji di hii Aatma ka Dushman
  13. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji di hii Aatma and your ytyyy
  14. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji dj mix of both jfvvvnnnwn
  15. रुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call jiरुपया आसान ग्राहक सेवा नंबर ♠✓ 797-0355+140 → 916-3467+314 Call ji shu
  16. Last week
  17. There is a Search panel to search manufacturers and another for models. Maybe an external USB keyboard would help? If you have a recent ZerOS, your most recent patch fixtures should be at the top of a list as "favourites". https://www.zero88.com/manuals/zeros/patching/add-fixtures/searching-filtering
  18. Bonjour, comment retrouver mes marques de projecteurs ( caméo, robert juliat, Stairway) sans passer par la bibliothèque ? À chaque fois que patch , il faut que je les récupère dans la bibliothèque ce qui n'est pas très facile Merci
  19. Struggling with tight deadlines and complex assignments? MyAssignmentHelp.com is your trusted partner for academic excellence. From essays and dissertations to case studies and research papers, our expert writers deliver high-quality, plagiarism-free content tailored to your needs. Students across the globe rely on our timely services and round-the-clock support. Whether you're stuck with a topic or need last-minute help, we've got your back. With affordable pricing and guaranteed results, you can focus more on learning and less on stress. Visit MyAssignmentHelp today and take the first step towards academic success!
  20. Hi there, we have a problem with the default attributes of our LED Fixtures. Till version 7.___ it was without problems possible to record the defaults atttributes for each fixture with "record" "home" "defaults". Now with version 8 thsi works as well but it happens the following: after each restart even if the values of all attributes are recorded correctly and double checked before switching of the concole, the default attributes are erased and it happens there are random attributes recorded e.g. white 82, red 0, green 18 and blue 2. Can anybody help? One more thought: Perhaps it's only coincidence and has nothing to do with the new version of the ZeroOS and the internal memory of our Console is damaged!? Best, Bernhard
  21. Earlier
  22. This video on multicell for FLX S might help, or as revision:
  23. I have some pixel batten fixtures. When I run a chase effect across a fixture it chases across those pixels. When I run the effect across multiple fixtures, it will chase across them all in order. I’d like for all the battens to pixel chase at the same time as a group. I thought it could be something to do with the offset of the effect, however when I select ‘offset as group’ it ignores the pixels and treats each batten as a single light source. I’ve attached a video of how it works currently and an edited video of how I want it to be able to work. How it works now: https://youtu.be/gVSUg7lTL2w How I want it to work: https://youtu.be/qIHcmw-siQs Is there something I’m missing? Thanks!
  24. Davidmk
    ninian
  25. Nin
    ninian
  26. @dtyotam See this post for links to the (Google) Apps:
  27. Hi @dtyotam I'm pretty sure that the Google Play Store deleted/closed the account that the remote apps were under, after they transferred over to Vari-Lite and Zero 88 was no longer under Cooper. This therefore rendered the apps un-downloadable. I'm not sure if there is another possible solution to download them, maybe an APK file? I just thought I should share this information.
  28. Ooh, this looks very promising. If it works (on our board) this might be just what I'm looking for. I'll let you know. All your help is very much appreciated, in any case, many thanks.
